***PSA for those with a New DAHUA NVR with Built-in PoE switch
bigredfish
25,990
68,819
The Swamp
IF you have a Dahua NVR with built-in PoE switch...
DO NOT follow instructions telling you to use the config tool or switch the IP of your cameras or initialize anything..!
With NVR's typically with a -P designation (Built-n PoE switch - example: 4208-8P-4KS2) none of that is required and it will often make a mess of things.
*On initial setup for the NVR and cameras, DO NOT enable P2P in the popup that asks you this. Uncheck that along with Auto updates. If you wish you can enable these later easily.
1- Fire up NVR using a mouse and monitor to do the initial setup, security questions, password, leave default Networking/IP alone (Verify it is static IP at 192.168.1.108 - assuming a standard home network of 192.168.1.x ), If you wish you could change the NVR IP address to some other static number on the 192.168.1.x network, This might be helpful if you were to add other Dahua cameras later outside of the built in PoE ports via say an external PoE switch as Dahau cameras connected this way will also default to the .108 address and create a conflict. . (I like to use .254 as I’ve yet to see that get assigned randomly by the router DHCP pool in a normal home environment)
Then disconnect from the NVR and never go back to that machine interface. Dont try and make any other setting changes here. You can change it all later in the Web interface.
2- Plug in your cameras to the NVR. Dont do anything else. The beauty of a PoE NVR is you dont have to do a damn thing, just plug them in, dont go clicking on buttons and shit when you dont know what youre doing, It WILL F$@k things up.
*Dont try to manually add them or force them to the bottom pane. Wait. Sometimes it takes a bit.
3 Open a browser on a PC on your network (again assuming a standard home network of 192.168.1.x) and type 192.168.1.108 or the IP you changed it to, and hit Enter. You will go to the WebGUI interface of your NVR. This is how you will manage your NVR from now on. Login with the name and pass you assigned the NVR
4- Assuming the newer 4.0 dark interface, Choose "Management" at top left then "Camera". This will take you to a page (Registration) that looks like the thumbnail below. The NVR will have automagically assigned each camera a channel and an IP address in the 10.1.1.x range** and a port of 1,2,3 etc.. You can NOT access the cameras without going through the NVR interface and using the Blue IE icons. See thumbnail below. (well you can access them but its a PIA and not necessary)
5- Click on the BLUE IE icon to open the individual cameras Web GUI to make changes to your camera settings, IVS, etc. The login for each new camera will default to Admin/your NVR password
The Login and Password for each camera will be identical and the same as your NVR. Dont F$@K with them!
*On initial login/setup for the cameras, DO NOT enable P2P in the popup that asks you this. Uncheck that along with Auto updates.
* It seems some older cameras and/or cameras that had already been initialized with another NVR, may retain their "old" password, but new Dahua cams out of the box will assume the same login credentials of the NVR via synching.
If you see a red dot next to a camera, and/or a gray IE icon that does not open the camera GUI in a new window as expected, its likely that the password on the camera is different than that of the NVR. If so, using the "pencil" icon, edit the password information for that camera to the password you may have previously set on another NVR or installation.
*The Edit dialog does not change anything on the camera. It simply allows you to edit the information of the camera that the NVR uses to communicate with the camera.
Notes
A -When you go to the camera registration page, do not try and add cameras attached to the built-in PoE ports manually to move them from the top pane to the bottom. Let the NVR do it automagically, May need to unplug them and reboot once. WAIT! It may take a few minutes for them to appear in the bottom pane. DO NOT be tempted to manually add them or move them from top to bottom panes.
If the camera does move to the bottom and is assigned a correct 10.1.1.x address but you continue to get a red indicator, another option is to open the camera access panel, and while still connected to the NVR, press and hold the reset button for 30 seconds. Then unplug it, delete the entry from the registration page, and plug it back in.
B- If using a Dahua NVR with the bullt in Poe switch, cameras using the built in PoE ports and showing port 37777* can’t be reached via the interface (IE button) as noted. Usually see this if you try to add them manually from the top pane to the bottom. (Or if you are using a splitter or extender and trying to run multiple cameras off of One PoE port. I dont recommend it) If you let the NVR assign and pass credentials by itself, they’ll show up as port 1,2,3 etc and you’ll be able to access them via the IE button
*UPDATED:
When using the built-in PoE ports, the NVR will assign them an IP (10.1.1.x) and a local port (1,2,3) and they will automatically populate the bottom pane as described above. You cant add them manually or it will mess up.
On cameras connected via external switch (like the ones shown at 192.168.1.x in the thumbnail below) you search for them in the top pane, and then have to add them to the bottom manually. These cameras connected via external switch will use port 37777. These you need to add one at a time and login to the camera and assign it an IP other than 192.168.1.108 as that is the default IP for all Dahua cams. Then add another and assign it another IP and so on, one at a time.
Also, cameras using an external switch CAN be accessed directly via their IP address.
C- I’ve found it works best not to mess with any settings other than Network and Recording schedule on the NVR. I make all Image, Exposure, Event, and FPS/Bitrate changes on the camera itself >>>> and it pushes them to the NVR fine. Making image and Event changes on the NVR does not always push them correctly to the camera however.
D- For day to day viewing/playback and downloading of clips on your home network, simply download and install Dahua SmartPSS on a computer on that network and use it. This is simpler and better than trying to use the NVR web interface all the time just to view cameras or download footage. That said, dont try and use SmartPSS to adjust or mange the camera image or Event/MD/IVS settings Do this on the camera itself.
E) Note: Its best to limit changes to Image, Encoding, Bitrate/FPS, IVS, Motion Detection, etc to one device or the other, I recommend using the camera interface. If you make some changes on the camera and others on the NVR, it will mess up something eventually
Questions:
Does the pencil icon pop-up on the nvr camera registration page modify the camera password or is that only so you can login into the cam?
It just allows you to enter the proper credentials already on the camera for the NVR to communicate with the camera, it does not modify the login/password of the camera
You said when you plug a cam into the NVR it changes the camera password to the nvr password but i didnt' find this to be true.
On a new camera or one factory defaulted and using the built-in PoE ports on the NVR, I can assure you it assigns the NVR password to the camera. If you have changed the camera settings somehow directly, installed the camera on another NVR previously, changed the IP or messed with onvif or ports, it may not adopt the NVR credentials and you may need to A) use the "old" password you originally set for the camera, or B) factory default the camera and start over.
If my cameras are now on the NVR private network of 10.1.1.x how can I view them without going through the NVR interface first?
The same way you would with an NVR without built-in PoE ports. By using SmartPSS (desktop), or the Dahua Mobile apps DMSS, iDMSS or gDMSS. They will "see through" the NVR to allow you to view your cameras. Remember, use these apps to view and download video clips. If you want to make changes to the Image, Events etc, do it on the camera itself.
Can I still use a VPN? Wont that be a problem again with the cameras on the 10.1.1.x network?
Yes. You will access them the same way as above. The VPN puts you inside your network as if you are sitting at your desk at home.
NVR 4.0 Setting up Recording
If you are not recording to an SD card on the camera itself, all recording functions should be set on the NVR. See each screen below to insure you are recording all events plus full time video.
Seeing IVS events in the playback timeline
a number of things have to be set to record and see IVS events on the playback timeline
1- On the NVR set the Schedule and make sure you have both Regular and IVS shown for each day (*also do same on snapshot for IVS and Motion only)
2- On the NVR Set to Record like this
3- On the Camera set Smart Plan for IVS (light bulb highlighted)
4- On the Camera make sure the "record" box is ticked for your IVS rule
5- Now on the NVR PLAYBACK tab you should see colored hash marks for IVS events as well as the green full-time recording
(showing examples from both the new 4.0 dark UI as well as the older "light" colored UI)
*Note use the slider at bottom right to zoom into the timeline
Playback via NVR web interface. USE IE or you won't see some controls
You can also use 'Backup" and download by timeframe
**** Please note: I use and recommend SmartPSS to view and playback or download clips. It’s easier and is a better interface. But per above you can do it on the NVR.
Download SmartPSS here
Thanks a lot for this thread. I have a NVR5232-16P-4KS2E coming from Andy. This is my first nvr and I know your tips will come in handy.
I cannot access my cameras via IE. I manually moved them from the top pane to bottom. Will they populate to the bottom screen if the cameras are already set up or do they need to be reset first? What about a wifi camera?
No idea on WiFi cameras... if they are new Dahua they should work similar
If you have manually assigned static IPs and/or ports to the cameras you may have problems.
Each case is different depending on many factors. Please start another thread in the NVR forum so that we can troubleshoot your specific problem.
Reactions: VorlonFrog
DO NOT follow any instructions telling you to use the config tool or switch the IP of your NVR or cameras or initialize anything..!
snip
5- Click on the BLUE IE icon to open the individual cameras Web GUI to make changes to your camera settings, IVS, etc. The login for each camera will default to Admin/your NVR password
Just received my nvr from Andy and am setting it up. I click the blue IE icon, log into the camera and I am immediately presented with this this screen"
I assume I should uncheck P2P?
Thanks.
Reactions: Arjun
Good question in the new 4.0 interface, I really dont know? Seems it just takes the name from the camera itself. Assign at the camera
When you say 'from the camera itself', do you mean by logging into the camera using the IE icon? If so, the only thing I could find there is under System --> General. But the name there does not correspond to the default name and changing it, does not update the camera name shown in the camera feed or in the nvr camera management section.
This is a bit of a mystery. Perhaps I will ping Andy to see if he knows.
I've upgraded to 4.001
I know in the previous version you could change it to. But can't remember where.
I am on 4.000. Interesting, I wonder if that is the difference.
Regardless, I found you can make the name change in SmartPss.
