bigredfish
Smart IR is on- turn off
Day/Night is set to Auto. Set to B&W
IR manual is set to 0 - set to 100
Yeah, I seen Smart IR was on under exposure after I posted the screenshots. I guess with that on, the manual illumination would not work as it should. Will make the necessary changes and report back tonightSmart IR is on- turn off
I made the changes to all 3 that were suggestedThe other two are just as important.
Yeah, I totally missed the setting under exposure, I just assumed it was under illuminator, my badYep, that is why in Post #34 I asked if Smart IR was on - at that low height, that IR bounce will wreak havoc on the IR as you saw with the pulsating as the camera was trying to Smart IR to eliminate washout and will throttle back the amount of IR.
You will see a big improvement tonight in the amount of IR. You will probably have to manually tone it down due to the height, but you will get better control that way.
Smart IR works in certain situations, for many, manual is the way to go.
Yep, there definitely is a science to this shhh --- stuff and a lot of experimentingAs you zoom in, the area of focus can get smaller and give that soft or out of focus in other areas.
I will usually autofocus and then change the focus step from 20 to 1 and do incremental manual adjustments to find the optimal focus for my intended target as sometimes the auto focus may decide to focus on something near or far from your intended focus distance.
No joy on flipping the camera, it makes no perceivable difference.I forget, are the LEDs at the bottom of the turrets? If so, it might be helpful to install it upside down to gain a little distance between the LEDs and the ground, to keep it from being blasted with the reflection. If you do flip it over, you will then adjust the rotation in the GUI settings.
I would like to find an IR spot similar to the one circled in the photo below to mount to the driveway side of the post. Any ideas?
empiretech01.com
If you go back to page one, you'll see why that isn't a good solution to this problemYou could get this IR spot that also triples as a camera.
EmpireTech IPC-B52IR-X3 1/2.8" CMOS 3 × 2 MP Triple-Sight Perimeter Pr
3 × 2MP 1/2.8" CMOS image sensor Built-in 8 IR LEDs, the max. illumination distance is up to 100 m Supports long-range perimeter protection Deep learning algorithm Supports max. 1TB Micro SD card Supports two-way talk ePoE IP67 and IK10 protectionempiretech01.com
It was a joke because the thing is an IR cannon.If you go back to page one, you'll see why that isn't a good solution to this problem![]()
I'd love to get my hands on one but have to wait for now. Have enough cameras and projects at the momentIt was a joke because the thing is an IR cannon.
