Progressive Live View Delay
MChevrier
May 10, 2020
17
6
Montreal, Quebec
Here's an updated summary in English for Reddit/Facebook/ipcamtalk:
Blue Iris - Progressive Live View Delay (~16 hour cycle) - SOLVED WITH WORKAROUND
System specs:
  • Intel i5-12600K, 32GB DDR5 4800MHz
  • ASUS PRIME Z690-P (DDR5 version)
  • 11 Lorex E891AB cameras (4K H.264, 15fps, 8192 Kbps) + 1 E892AB (disabled - clock issues)
  • Blue Iris 6.0.9.3
  • CodeProject.AI with YOLOv5 6.2 .NET and Face Recognition uninstalled
  • Windows 11, HP ProCurve 3500yl-24G POE switch
  • Storage: 18TB HDD for recordings D: of 5 cameras, 20TB HDD E: for recording of 6 cameras, SSD for DB C:
  • Realtek Gaming 2.5Gb NIC
Problem:
Live view delay starts at 0 seconds after BI service restart, then progressively increases over ~16 hours until reaching 1-2 minutes. Restarting the BI service immediately fixes the delay until it accumulates again. System occasionally freezes requiring a wait before becoming responsive again.
What we verified/ruled out:
  • CPU usage: ~28-35% ✅
  • RAM usage: ~68% ✅
  • GPU usage: ~14% ✅
  • Disk usage: ~8% ✅
  • Network: occasional spikes to 10-29ms but not consistently correlated with delay ✅
  • No thermal throttling (CPU temps 45-55°C) ✅
  • Power plan: High Performance ✅
  • Single camera test: delay still present (~40-60 sec) — not a multi-camera resource issue ✅
  • CodeProject.AI disabled: delay persists ✅
  • GOP/I-Frame interval: set to 15 on both main and sub streams ✅
Settings optimized in Blue Iris:
  • Receive buffer: reduced to 1.0 MB on all cameras (was 6-20MB)
  • Limit decoding unless required: unchecked on all cameras
  • Hardware accelerated decode: Intel® +VPP (global setting)
  • Hardware decode per camera: Default (inherits global)
  • Stream buffer time: 2.0 sec
  • Decoder compatibility mode: unchecked
  • Use RTSP/stream timecode: unchecked
  • Send RTSP keep-alives: checked
  • Max AI analyzers: reduced to 1
  • Bit exact: unchecked
  • CPU usage factor: 1.000
Settings optimized on Lorex cameras (via web interface):
  • Main Stream: H.264, 4K (3840x2160), 15fps, CBR, 8192 Kbps
  • Sub Stream: H.264, 704x480, 15fps, CBR, 256 Kbps
  • GOP Main Stream: 15 (1 keyframe per second)
  • GOP Sub Stream: 15 (was 1 — caused excessive bitrate ~3644 kB/s)
  • NTP time sync enabled with correct timezone (EST/EDT)
  • Firmware updated to V18 on all E891AB cameras
Other fixes applied:
  • DB repair completed successfully (DBRegenerate: success)
  • Startup apps disabled: Microsoft Teams, Edge, Mobile Devices, Logitech Download Assistant
  • Face Recognition and YOLOv5 .NET uninstalled from CodeProject.AI *********
  • Sub stream GOP corrected from 1 to 15 (critical — was causing abnormal sub stream bitrate)
Current workaround:
Scheduled automatic BI service restart twice daily via Windows Task Scheduler:
  • 03:00 and 15:00 every day
  • Command: cmd.exe /c sc stop BlueIris && timeout 10 && sc start BlueIris
  • This keeps the delay within acceptable range (~0 seconds) as long as BI has been running less than ~16 hours
Root cause — still unknown:
Despite all resources being available (CPU, RAM, GPU, disk, network), BI progressively accumulates a buffer over ~16 hours that causes live view delay. The buffer resets completely with a service restart. No obvious bottleneck identified. Could be a memory leak in BI? A known bug with 4K RTSP streams?
Question for the community:
Has anyone experienced this exact pattern — progressive live view delay that accumulates over ~16 hours and resets with a service restart, with no resource saturation? Any insight into the root cause would be greatly appreciated!
