If you are bandwidth-limited then sub streams might not be the best option because like crw030 said, they both get streamed simultaneously from the camera to Blue Iris. If you are using H.264 right now, H.265 with a lower bit rate limit would be advisable. You should be able to get similar visual quality at 50-75% of the bit rate when transitioning from H.264 to H.265.
