Ever since upgrading to version 5 BI is twitchy, slow and keeps messing up. All kinds of weird things. I wish I could go back to V4 without having to reprogram everything.
There is nothing wrong with v5....this is user error. Perform a clean install of v5I don't have the time to help BI fix the bugs with V5. I simply want to know if I can go back to V4 without have to start all over. I have everything written down so I can do it but if there is an easier/faster way to go back that would be preferable.
are you running the second machine in demo mode?Just finished setting up a second machine with V5 to run alongside V4. Runs higher on the CPU but otherwise haven’t noticed anything else. Machines are identical other than the V5 machine has max RAM at 32GB
Right after upgrading to V5 my screen started jumping randomly. The windows task bar at the bottom of the screen will appear for no reason and then disappear making the screen shift up and then down even though the mouse is now where close to the bottom of the screen. When I choose to look at a video on the left side of the screen the program will just close so I am unable to look at any past videos. If I ext the program and then start it again it doesn't always start and sometimes it will start but not all of it. If it does start it is extremely slow. My network is not connected to the internet (unless I plug it in for upgrades). I guess if there is no way to go back to V$ without reentering everything from the start I might as well do that.Very odd.
V5 has been working rock solid for me. And the look and feel is a lot better than V4.
What problems are you having or is this just a random complaint?
I was having no problems with V4. All of my problems started after upgrading to V5. My system has not worked since then. I have spent hours trying to fix it. I think at this point I will just delete everything and do a clean install of V4 and reenter all of my cameras. UUUgh, the time.There is nothing wrong with v5....this is user error. Perform a clean install of v5
