Problem with DS-KV6124-WBE1
dex_910
Jul 26, 2026
1
Poland
Hello,
I'm having an issue with my DS-KV6124-WBE1 door station.
My setup is:
  • Router: TP-Link Archer AX55
  • Switch: TP-Link TL-SG1016PE v6
  • Door station: Hikvision DS-KV6124-WBE1
  • Indoor monitor: DS-KH8520-WTE1
All devices are running the latest available firmware. The door station firmware is V3.9.0 build 251216.
The problem is that after approximately 24 hours, I lose the ability to establish an audio/video connection through Guarding Vision (Hik-Connect).
When I try to start live view, the app eventually reports that the streaming timed out.
At the same time:
  • I can still remotely unlock the gate.
  • I still receive push notifications when someone rings the doorbell.
  • The indoor monitor works normally.
  • The web interface works normally, including both video streams.
  • Both RTSP streams work perfectly in VLC.
  • Platform Access (Guarding Vision) shows Online in the web interface.
So far I have tried:
  • changing the DNS servers (1.1.1.1 and 8.8.8.8),
  • verifying time and NTP settings,
  • changing the switch port,
  • disconnecting the switch from the router,
  • disconnecting the router from the Internet,
  • rebooting the router,
  • assigning a DHCP reservation (static IP) to the door station.
The door station is connected via wired Ethernet with PoE.
When I disable Platform Access (Guarding Vision) and immediately try to enable it again while the problem is present, the device reports Offline.
The only thing that restores audio/video is rebooting the door station.
I'm slowly running out of ideas. Has anyone experienced a similar issue or knows what could be causing this?
