No...the camera will be fed by a POE switch on the side of the road that has the receiving transmitter, which will also be fed by the same POE switch....So no power? You're planning to go solar?
and where will the electrons that power it come from?No...the camera will be fed by a POE switch on the side of the road that has the receiving transmitter, which will also be fed by the same POE switch....
There is a building with power between where the pole will be for the receiving transmitter and where the camera will be. Both camera and receiver will connect via RJ45 to the POE switch and get power. The main issue I'm having is getting from the NVR to the far out camera, because I have to cross a road.and where will the electrons that power it come from?
I have been using Mikrotik radios for point to point links for years. I have one on our farm that is around 2km away and has no LOS. Its LOS passes through about 10 metres of a hilltop. I was very surprised when I first set it up that it worked at all. The remote site is a solar powered system with a Dahua DH-SD29204UE-GN and also an OpenWRT wifi AP, just in case the cattle, kangaroos, feral pigs, crows, parrots, etc need wifi access. Do get some great captures from there. Line of sight is about where the red dot in the red circle is. When I first started to use Mikrotik around 12 years ago, they were much cheaper than anything else. Ubiquity work just as well, I believe.
Can you provide a "link" to the "link" ?At this point I wouldn't consider anything else because you can get a full Mikrotik 5GHZ AC link for $100.00
Ya, would love to see this amazing gadget...Can you provide a "link" to the "link" ?![]()
That's great!Except for the occasional Amazon / UPS truck stopping right between the two antennas I should have no issues with LOS
Do they use 2.4 or 5GHz? Especially the feral pigs.OpenWRT wifi AP, just in case the cattle, kangaroos, feral pigs, crows, parrots, etc need wifi access.
Thanks!Mikrotik SXTsq 5 AC. Just a quick search, and its probably gone up in price a bit, but it is listed at $65 per radio on their site. There are many resellers available in all countries so finding them is fairly easy.
MikroTik
MikroTik makes networking hardware and software, which is used in nearly all countries of the world. Our mission is to make existing Internet technologies faster, more powerful and affordable to wider range of users.mikrotik.com
SXTsq 5 ac | MikroTik
Low-cost small-size 16dBi 5GHz dual chain integrated CPE/Backbone with AC support and Gigabit Ethernetmikrotik.com
You need two per PTP link. One is setup as an AP bridge and the other is a bridge. If you have line of sight as in a clear fresnel zone you should be able to get ~300Mbits/sec with a link like this. It comes with a POE injector as it does not conform to the 802.3af standard. If you need more throughput there are other options on the site. You should be able to get a few miles out of this link if needed, but it is fairly small and compact so one with a larger antenna would be required if you want to go 10-20 miles.
Thanks!
Nice alternative to Ubiquiti for now, as they are scarce and pricey....I hope that's temporary. I may just try a pair on my next link that I need for someone (waiting for phone to ring).
Not too thrilled about the form factor of the POE injector and wall wart for power, though (image at bottom)...reminds me of some earlier Engenius and TP-LINK gear. But it's likely pins 4/5 for positive and 7/8 for negative since it's passive, I've got a dozen Ubiquiti 18 and 24VDC POE injectors laying around.
It seems they'll squeeze another $3 out of you for a pole mount, several competitors make that provision in the design of the radio. It's not a deal breaker certainly so I'll definitely try a pair next go-round.
Does this building have it's own electric meter or is the power fed from the main structure on the other side of the road?There is a building with power between where the pole will be for the receiving transmitter and where the camera will be. Both camera and receiver will connect via RJ45 to the POE switch and get power. The main issue I'm having is getting from the NVR to the far out camera, because I have to cross a road.
Own electrical meterDoes this building have it's own electric meter or is the power fed from the main structure on the other side of the road?
No worries. Just wanted to confirm that I'm looking for standard POE 802.11F or whatever the standard is so that I don't need a power injector at the point of transmission, I can run it from a POE NVR.That's great!
I likely got your situation crossed with someone else's, as there has been a LOT of posts regarding such links in the past week.![]()
I don't see why not....just remember they use a 24VDC pasive POE injector (included).Sounds like Mikrotik SXTsq 5 AC wouldn't work for me, but would the ones you suggested?
I'd perform a site survey and see what the noise floor is, if not a lot of ambient 2.4 GHz I'd try that using a higher power/higher sensitivity radio like the Nanostation M2 which is rated 23 dB minimum. BTW, just saw them in stock at Ubiquiti for $89 which will NOT last long if it is, in fact, in stock and at that price.
yes.@TonyR - This might be a dumb question... You would need two of these devices to setup a Point to Point within line of sight correct?
Trying to keep it as simple as possible. If I can use standard POE protocol and only need one cable connected from the transmitter and receiver to a POE type switch, then that simplifies things greatly...I don't see why not....just remember they use a 24VDC pasive POE injector (included).
No worries at all, you have been very helpful.I spent about 15 minutes looking for Ubiquiti, Mikrotik, Engenius and TP-LINK outdoor, PtP AP/bridges that did NOT use either 24VDC passive or "proprietary" 54 volt power injectors and came up empty handed. Engenius specs may be the closest but they are ambiguous, stating "proprietary" and "54 volt" in one part of specs but mentioning compatibality with POE cameras and switches in another.....so it's unclear. Sorry I cannot be of more help in that regard.
Could be why the 802.3af POE-to-24VDC adapter came about.![]()
