any chance he has a graphics driver problem?
How would I go about fixing it if true?
Last night I updated the Intel graphics drivers through the Intel Driver and Support Assistant to see if it would have an effect. It didn't.
The nice thing about incremental daily backups is you can go back to a healthy image before the trouble began.
Macrium Reflect, or any other backup program, that has daily incrementals. when shit goes sideways...you can revert to the last known good backup before all hell broke loose....then if it was a software issue it will clear up, if it's a hardware issue then it may remain.Incremental daily updates? Where?
Look at the RAM creeping up.
Why is the GPU still so high?
There is something else going on with your system itself outside of BI that needs to be addressed.
I did the "reset this PC" and it removed everything from HP that was Bloatware. using the Run as Administrator Command line from somebodies post on here.
"I can tell you how to get a quick and easy perfect installation of Win 10.( that could probably be done remotely too.) It leaves your Apps intact but completely removes and replaces Windows. Furthermore, it comes with all the latest updates installed so no updating needed (it's usually the updates that break Windows). Did I say it's very fast. Think 10 minutes not 3 days.
Ok it's a 3 step process but quick. 1st step is really a system check and can be skipped or run alone without step 2 or 3. However, if you run step 2, either after step 1 or without step 1, you must run step 3.
Hope that makes sense. Step 1 is a more comprehensive version of the system check utility and sometimes fixes items the Windows run one can't. However, it doesn't fix everything, and whilst worth trying, sometimes only a re-installation will do.
Step 1:
dism.exe /online /cleanup-image /scanhealth
Step 2:
dism.exe /online /cleanup-image /restorehealth
Step 3:
dism.exe /online /cleanup-image /startcomponentcleanup
Do the DISM and sfc commands work in WIN11? - maybe you have a corrupt install and see if those will detect and correct it.
