So about an hour ago I noticed my Dahua cameras names changed to p2pwn on the live view along with P2PWNED DEVICE IS VULNERABLE. Is there a fix regarding this issue? Thanks.
And now on cameras I am seeing reserved user accounts.. what a mess. Most of my cameras have no newer firmware update I am aware of but will ask Andy and check all these settings.
And if you are indeed using a PoE NVR with cameras directly attached to it, there is NO good reason to have P2P enabled on them. The NVR will handle it
Andy still has many of the Dahua 5442 series (54IR series using his naming system)
These are still the go to cameras
Each location/scene is different, possible another model may be better for any given scene but that requires seeing a picture of the scene at night (daytime they'll all be fine)
EmpireTech is dedicated to providing top-tier technology and goods, including multi-sensor dual lens cameras, ePoE with 800m transmission via Ethernet cable, AI Codec to enhance encoding efficacy and conserve bandwidth, and precise, reliable, and exact deep learning algorithm.
