Orllo z10 cam- Blue iris
kripp_83
Jul 22, 2020
1
swe
Hi been member long time but first time i post.
I bought a Ptz camera i cant get to add in blue iris. cant find it even tho i know the ip adress of it. never had this problem before. i can add sreenshots, if so let, me know of what.
Assuming the camera's default IP is on the same subnet as the BI server and you inserted into BI the IP, username, password and clicked on "Find/inspect", please post a screenshot of the results popup.
The manufacturer's Polish site, orllo.pl, blocks my access for some reason. I did find specs here and it states there's is a RTSP stream and that it's ONVIF-compliant.
If BI's Find/inspect doesn't work, try ODM. Insert user/pass and it should find the camera if it is ONVIF-compliant. Click on "live video" in middle column and the RTSP URL should appear down at bottom of the right hand screen.
