PSPCommOp
My night time viewing sucks... Yeah I will get a 8 channel nvr.... I may try the Illuminators, but I don't want to put anymore holes in the brick or vinyl, so that may be out of the question?? If I do them I'm not sure what to buy or how to wire them up? I have power in my attic for another Poe switch if needed.
If you don't mind the extra switch try
This
https://www.amazon.com/dp/B017J8WJ5...olid=2063V1TE20WMK&coliid=IHDQH4J53Y2NQ&psc=1
Plus something like this
https://www.amazon.com/dp/B00M3O5ER...UTF8&colid=2063V1TE20WMK&coliid=IYSW7TP2AJFIX
or any other reliable IR illuminator that youd like.
This is what I plan on doing for mine, my EXIR turrets are good but at two points around my house the EXIR doesn't have the distance to light up what I'd like.
Its as simple as running a new Cat5/6 cable to where the camera is, plugging it into the 12v splitter and using the power from that to operate the light. Most decent IR Illuminators will have a sensor to turn off and on when it gets dark. I'm also told you can use the RJ45 jack on these to connect to the camera and just use the 12v adapter to power the light if you put them near it each but I haven't tried that and don't plan on it.
