I'm looking for two "inexpensive" IP cams to be installed inside of the garage, well....actually two garages if you will. See pic below, the other side of the house is identical. The cameras will be mounted inside about 15 feet back from that center entrance door. The primary reason for the cams is just to verify the doors are down (closed) but also to alert if someone walks in or a vehicle drives in. The lighting will be mostly what comes in the garage door windows in the day and most likely very little light at night.
The picture shows a side that faces due south and the other unseen side due north. The lighting will be mostly what comes in the garage door windows in the day and most likely very little light at night with the exception of the garage door opener light if it's been recently opened.
For inexpensive IP cams I present the following list. Which of these would you recommend as the best to go with? I have a N22AL12 so I know what to expect from it. You can see that the extended cost for two cams is not significant so may as well just go with what the best fit is.
| Brand | Description | Cost | Extended |
| Dahua IP Camera (x2) | 2MP IR Dome (N22AL12) 2.8mm | $69.99 | $139.98 |
| Amcrest IP Camera (x2) | 5MP IR Turret (IP5M-T1179EW) 2.8mm | $57.99 | $115.98 |
| Dahua IP Camera (x2) | 4MP IR Turret (IPC-T2431T-AS) 2.8mm | $74.99 | $149.98 |
