Main CPU is loading up between 30-40%, up and down, container CPU usage has been variable, seems to sit at 30-40% for a while, then dropped back to 6%, backup up again later to 35%, now 5 hours in on 25GB size DB, processor.db-shm and -wal files keep appearing then dropping out again. I have to assume something is happening, main DB file size has stayed the same throughout. Machine is a i5-8400 with 32GB RAM and Samsung 980 Pro 1TB, I jokingly refer to it as a new machine because it got built when that processor was released, then I could not face commissioning it, also regret not going for an i7 but there is always next time! The existing machine is i5-4690 so the step up is certainly noticeable, new one barely breaks a sweat with Rekor running, that alone would tax the older one quite a bit depending on feed quality.How's the CPU look? I had 1 core pegged at about 100% for a while, then it moved to a more mixed workload with all cores bouncing around, then went idle and it was done, then my logs came back
2024-06-15 17:19:17 [17:19:17 INF] Starting Hangfire Server using job storage: 'In-Memory Storage'
2024-06-15 17:19:17 [17:19:17 INF] Using the following options for Hangfire Server:
2024-06-15 17:19:17     Worker count: 20
2024-06-15 17:19:17     Listening queues: 'default'
2024-06-15 17:19:17     Shutdown timeout: 00:00:15
2024-06-15 17:19:17     Schedule polling interval: 00:00:01
2024-06-15 17:19:17 [17:19:17 INF] Server 686e7ee0c79f:1:c7d54d89 successfully announced in 2.4371 ms
2024-06-15 17:19:17 [17:19:17 INF] Server 686e7ee0c79f:1:c7d54d89 is starting the registered dispatchers: ServerWatchdog, ServerJobCancellationWatcher, Worker, DelayedJobScheduler, RecurringJobScheduler...
2024-06-15 17:19:18 [17:19:18 INF] Server 686e7ee0c79f:1:c7d54d89 all the dispatchers started - If I start version 5.3.0 with a blank database, it is fine, reads new plates no problem, so some issue with using the existing database with version 5.3.0. Now I know the notes for this version state:
 - If I start version 5.3.0 with a blank database, it is fine, reads new plates no problem, so some issue with using the existing database with version 5.3.0. Now I know the notes for this version state:docker run --net=bridge -e TZ=Etc/GMT-1 -d -p 3859:8080 -v "c:/alprwebhook/app/config/":"/app/config/" mlapaglia/openalprwebhookprocessor:v5.3.0I am running on version 5.2.0 at the moment due to permissions issues! but, I am getting a similar error as above, new vehicle only seen once, total seen count is 2, did you make any progress? I also still see 'disconnected' in settings but plates are getting logged.@CamCrazy did you say you have an issue with plates being counted twice? Because now with my fully working setup, I have the same issue!
Won't be permissions, that causes fail login, you won't even get running with that.Okay well at least we're in the same boat! I don't think I have a permissions issue going to 5.3.0, but it could be. I'll work on it some more today
Same issues as you, double count and shows disconnected. I just hope this doesn't forever alter the database, I make use of the count quite a lot
Yes indeed, 100% accurate. Version 5.3.0, Windows 11, Docker Desktop latest release, all updates installed.To confirm, you're seeing duplicate plates on 5.3.0 with a net new database?
That could be a good plan, not entirely sure whether just the latest release seems to be effected by this, or if it is a docker issue? hard to say, I did not test with 5.2.0 or prior.I wonder if I restore to a backup from before I upgraded, I'd hate this to forever alter the database count
Thanks for confirming, I might test the two previous versions tomorrow and see if they show the same results. I might even be able to confirm if duplicates get applied to historical entries, possibly.I'm on 5.2.0 and it has the issue
Did you make any further progress with the duplicates?I'm on 5.2.0 and it has the issue
apt install build-essential python3 python3-dev python3.10-venv pip3 redis-server && systemctl enable redis-server && systemctl start redis-server
git clone https://github.com/mibs510/OpenALPR-Webhook
cd OpenALPR-Webhook
python3 -m venv ./venv
source ./venv/bin/activate
# Due to a dependency issue with flask-dance, flask-dance needs to be installed separately from all other packages
pip3 install flask-dance
pip3 install -r requirements.txt
./app.py --host=0.0.0.0 --port=8080Collecting PyYAML==6.0 (from -r requirements.txt (line 69))
  Using cached PyYAML-6.0.tar.gz (124 kB)
  Installing build dependencies ... done
  Getting requirements to build wheel ... error
  error: subprocess-exited-with-error
  × Getting requirements to build wheel did not run successfully.
  │ exit code: 1
  ╰─> [67 lines of output]
      /tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/dist.py:759: SetuptoolsDeprecationWarning: License classifiers are deprecated.
              Please consider removing the following classifiers in favor of a SPDX license expression:
              License :: OSI Approved :: MIT License
              See https://packaging.python.org/en/latest/guides/writing-pyproject-toml/#license for details.
        self._finalize_license_expression()
      running egg_info
      writing lib/PyYAML.egg-info/PKG-INFO
      writing dependency_links to lib/PyYAML.egg-info/dependency_links.txt
      writing top-level names to lib/PyYAML.egg-info/top_level.txt
      Traceback (most recent call last):
        File "/home/openalpr/OpenALPR-Webhook/venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
          main()
        File "/home/openalpr/OpenALPR-Webhook/venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
          json_out['return_val'] = hook(**hook_input['kwargs'])
        File "/home/openalpr/OpenALPR-Webhook/venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 118, in get_requires_for_build_wheel
          return hook(config_settings)
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 334, in get_requires_for_build_wheel
          return self._get_build_requires(config_settings, requirements=[])
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 304, in _get_build_requires
          self.run_setup()
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 320, in run_setup
          exec(code, locals())
        File "<string>", line 288, in <module>
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/__init__.py", line 117, in setup
          return distutils.core.setup(**attrs)
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 186, in setup
          return run_commands(dist)
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 202, in run_commands
          dist.run_commands()
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 1002, in run_commands
          self.run_command(cmd)
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/dist.py", line 1104, in run_command
          super().run_command(command)
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 1021, in run_command
          cmd_obj.run()
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 312, in run
          self.find_sources()
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 320, in find_sources
          mm.run()
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 543, in run
          self.add_defaults()
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 581, in add_defaults
          sdist.add_defaults(self)
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/command/sdist.py", line 109, in add_defaults
          super().add_defaults()
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/sdist.py", line 245, in add_defaults
          self._add_defaults_ext()
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/sdist.py", line 330, in _add_defaults_ext
          self.filelist.extend(build_ext.get_source_files())
        File "<string>", line 204, in get_source_files
        File "/tmp/pip-build-env-sd2uxigy/overlay/lib/python3.12/site-packages/setuptools/_distutils/cmd.py", line 131, in __getattr__
          raise AttributeError(attr)
      AttributeError: cython_sources
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
note: This error originates from a subprocess, and is likely not a problem with piproot@calvin-DNB20-series:/home/openalpr/OpenALPR-Webhook# ./app.py --host=0.0.0.0 --port=8080
./app.py: line 23: import: command not found
./app.py: line 25: from: command not found
./app.py: line 26: from: command not found
./app.py: line 27: from: command not found
./app.py: line 29: from: command not found
./app.py: line 30: from: command not found
./app.py: line 33: syntax error near unexpected token `('
./app.py: line 33: `DEBUG = os.getenv('DEBUG', 'False') == 'True''aiohttp==3.8.4
aiohttp-retry==2.8.3
aiosignal==1.3.1
alembic==1.10.4
aniso8601==9.0.1
argcomplete==3.0.8
arrow==1.2.3
astral==2.2
async-timeout==4.0.2
asyncio==3.4.3
attrs==23.1.0
blinker==1.9
certifi==2022.12.7
cfgv==3.3.1
charset-normalizer==3.1.0
click==8.1.3
colorama==0.4.4
Cython==0.29.34
decli==0.6.1
distlib==0.3.6
dnspython==2.3.0
email-validator==2.0.0.post2
filelock==3.12.0
Flask==3.1.0
flask-ipban==1.1.5
Flask-Login==0.6.2
Flask-Mail==0.9.1
Flask-Migrate==2.6.0
Flask-Minify==0.41
flask-paginate==2022.1.8
flask-restx==0.5.1
Flask-Script==2.0.6
Flask-SQLAlchemy==2.5.1
Flask-WTF==1.0.0
frozenlist==1.3.3
greenlet==2.0.2
gunicorn==20.1.0
htmlmin==0.1.12
identify==2.5.24
idna==3.4
importlib-metadata==6.6.0
ipc-sun-sync==0.2.3
itsdangerous==2.2.0
Jinja2==3.1.2
jsmin==3.0.1
jsonschema==4.17.3
lesscpy==0.15.1
Mako==1.2.4
MarkupSafe==2.1.1
marshmallow==3.14.1
marshmallow-sqlalchemy==0.22.3
multidict==6.0.4
nodeenv==1.8.0
oauthlib==3.2.2
packaging==23.1
phonenumbers==8.13.11
platformdirs==3.5.1
ply==3.11
progressbar2==4.2.0
prompt-toolkit==3.0.38
psutil==5.9.5
pycountry==22.3.5
PyJWT==2.6.0
pyrsistent==0.19.3
python-dateutil==2.8.2
python-utils==3.7.0
pytimeparse==1.1.8
pytz==2022.1
PyYAML==6.0.1
questionary==1.10.0
random-password-generator==2.2.0
rcssmin==1.1.1
redis==4.4.4
Redis-Sentinel-Url==1.0.1
requests==2.28.2
requests-oauthlib==1.3.1
rq==1.12.0
setproctitle==1.3.2
six==1.16.0
SQLAlchemy==1.4.29
sqlalchemy-json==0.5.0
termcolor==2.3.0
tomlkit==0.11.8
twilio==8.0.0
typing_extensions==4.5.0
urllib3==1.26.15
URLObject==2.4.3
virtualenv==20.23.0
wcwidth==0.2.6
Werkzeug==3.1
WTForms==3.0.0
xxhash==3.2.0
yarl==1.17.0
zipp==3.15.0Building wheels for collected packages: aiohttp, Flask-Mail, Flask-Script, frozenlist, greenlet, htmlmin, jsmin, MarkupSafe, multidict, pycountry
  Building wheel for aiohttp (pyproject.toml) ... error
  × Building wheel for aiohttp (pyproject.toml) did not run successfully.
  │ exit code: 1 Building wheel for frozenlist (pyproject.toml) ... error
  × Building wheel for frozenlist (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [151 lines of output]
      /tmp/pip-build-env-3buxn6hj/overlay/lib/python3.12/site-packages/setuptools/dist.py:759: SetuptoolsDeprecationWarning: License classifiers are deprecated.
      !! Building wheel for greenlet (pyproject.toml) ... error
  × Building wheel for greenlet (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [152 lines of output] note: This error originates from a subprocess, and is likely not a problem with pip.
  ERROR: Failed building wheel for greenlet
