{"log":"[20:40:59 ERR] failed to register Agent\n","stream":"stdout","time":"2021-01-06T20:40:59.309747234Z"}
{"log":"System.Net.Http.HttpRequestException\n","stream":"stdout","time":"2021-01-06T20:40:59.309814977Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.AgentRegistration.RegisterAgentAsync(Uri serverUrl, String username, String password, Boolean ignoreSslErrors) in /src/OpenAlprWebhookProcessor/HeartbeatService/Registration/AgentRegistration.cs:line 42\n","stream":"stdout","time":"2021-01-06T20:40:59.309827923Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.HeartbeatService.RegisterAgentAsync() in /src/OpenAlprWebhookProcessor/HeartbeatService/HeartbeatService.cs:line 153\n","stream":"stdout","time":"2021-01-06T20:40:59.309838285Z"}
{"log":"Unhandled exception. System.Net.Http.HttpRequestException\n","stream":"stderr","time":"2021-01-06T20:40:59.320089774Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.AgentRegistration.RegisterAgentAsync(Uri serverUrl, String username, String password, Boolean ignoreSslErrors) in /src/OpenAlprWebhookProcessor/HeartbeatService/Registration/AgentRegistration.cs:line 42\n","stream":"stderr","time":"2021-01-06T20:40:59.320127786Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.HeartbeatService.RegisterAgentAsync() in /src/OpenAlprWebhookProcessor/HeartbeatService/HeartbeatService.cs:line 153\n","stream":"stderr","time":"2021-01-06T20:40:59.320140864Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.HeartbeatService.StartAsync(CancellationToken cancellationToken) in /src/OpenAlprWebhookProcessor/HeartbeatService/HeartbeatService.cs:line 45\n","stream":"stderr","time":"2021-01-06T20:40:59.320148622Z"}
{"log":" at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T20:40:59.320153405Z"}
{"log":" at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)\n","stream":"stderr","time":"2021-01-06T20:40:59.320157728Z"}
{"log":" at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)\n","stream":"stderr","time":"2021-01-06T20:40:59.320162297Z"}
{"log":" at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)\n","stream":"stderr","time":"2021-01-06T20:40:59.320168281Z"}
{"log":" at OpenAlprWebhookProcessor.Program.Main(String[] args) in /src/OpenAlprWebhookProcessor/Program.cs:line 21\n","stream":"stderr","time":"2021-01-06T20:40:59.320175203Z"}
{"log":"[22:03:48 WRN] 'AddEntityFramework*' was called on the service provider, but 'UseInternalServiceProvider' wasn't called in the DbContext options configuration. Remove the 'AddEntityFramework*' call as in most cases it's not needed and might cause conflicts with other products and services registered in the same service provider.\n","stream":"stdout","time":"2021-01-06T22:03:48.522542149Z"}
{"log":"[22:03:49 INF] Entity Framework Core 3.1.10 initialized 'ProcessorContext' using provider 'Microsoft.EntityFrameworkCore.Sqlite' with options: None\n","stream":"stdout","time":"2021-01-06T22:03:49.137697805Z"}
{"log":"[22:03:50 ERR] Failed executing DbCommand (18ms) [Parameters=[@__companyId_0='?' (Size = 36)], CommandType='Text', CommandTimeout='30']\n","stream":"stdout","time":"2021-01-06T22:03:50.175419414Z"}
{"log":"SELECT \"c\".\"Id\", \"c\".\"CompanyId\", \"c\".\"Username\"\n","stream":"stdout","time":"2021-01-06T22:03:50.17545565Z"}
{"log":"FROM \"Companies\" AS \"c\"\n","stream":"stdout","time":"2021-01-06T22:03:50.175466459Z"}
{"log":"WHERE \"c\".\"CompanyId\" = @__companyId_0\n","stream":"stdout","time":"2021-01-06T22:03:50.175473323Z"}
{"log":"LIMIT 1\n","stream":"stdout","time":"2021-01-06T22:03:50.175480613Z"}
{"log":"[22:03:50 ERR] An exception occurred while iterating over the results of a query for context type 'OpenAlprWebhookProcessor.Data.ProcessorContext'.\n","stream":"stdout","time":"2021-01-06T22:03:50.213416809Z"}
{"log":"Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such table: Companies'.\n","stream":"stdout","time":"2021-01-06T22:03:50.213450659Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)\n","stream":"stdout","time":"2021-01-06T22:03:50.213456465Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements(Stopwatch timer)+MoveNext()\n","stream":"stdout","time":"2021-01-06T22:03:50.213460624Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.GetStatements(Stopwatch timer)+MoveNext()\n","stream":"stdout","time":"2021-01-06T22:03:50.213464635Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()\n","stream":"stdout","time":"2021-01-06T22:03:50.213468574Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)\n","stream":"stdout","time":"2021-01-06T22:03:50.213472575Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213476492Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteDbDataReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213480536Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213484559Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213489043Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213493814Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.Internal.QueryingEnumerable`1.AsyncEnumerator.InitializeReaderAsync(DbContext _, Boolean result, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213497852Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.Internal.QueryingEnumerable`1.AsyncEnumerator.MoveNextAsync()\n","stream":"stdout","time":"2021-01-06T22:03:50.213501903Z"}
{"log":"Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such table: Companies'.\n","stream":"stdout","time":"2021-01-06T22:03:50.213505882Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)\n","stream":"stdout","time":"2021-01-06T22:03:50.213510444Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements(Stopwatch timer)+MoveNext()\n","stream":"stdout","time":"2021-01-06T22:03:50.213531703Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.GetStatements(Stopwatch timer)+MoveNext()\n","stream":"stdout","time":"2021-01-06T22:03:50.213537807Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()\n","stream":"stdout","time":"2021-01-06T22:03:50.213541829Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)\n","stream":"stdout","time":"2021-01-06T22:03:50.213545852Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213549875Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteDbDataReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213553834Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.21355785Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213561977Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213566072Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.Internal.QueryingEnumerable`1.AsyncEnumerator.InitializeReaderAsync(DbContext _, Boolean result, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.213570234Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.Internal.QueryingEnumerable`1.AsyncEnumerator.MoveNextAsync()\n","stream":"stdout","time":"2021-01-06T22:03:50.213574376Z"}
{"log":"[22:03:50 ERR] failed to register Agent\n","stream":"stdout","time":"2021-01-06T22:03:50.227443996Z"}
{"log":"Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such table: Companies'.\n","stream":"stdout","time":"2021-01-06T22:03:50.22747266Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)\n","stream":"stdout","time":"2021-01-06T22:03:50.227481234Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements(Stopwatch timer)+MoveNext()\n","stream":"stdout","time":"2021-01-06T22:03:50.227487919Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.GetStatements(Stopwatch timer)+MoveNext()\n","stream":"stdout","time":"2021-01-06T22:03:50.227494566Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()\n","stream":"stdout","time":"2021-01-06T22:03:50.227500814Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)\n","stream":"stdout","time":"2021-01-06T22:03:50.227508059Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.227512128Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteDbDataReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.227516188Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.227520315Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.227524417Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.227543916Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.Internal.QueryingEnumerable`1.AsyncEnumerator.InitializeReaderAsync(DbContext _, Boolean result, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.227548995Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.Internal.QueryingEnumerable`1.AsyncEnumerator.MoveNextAsync()\n","stream":"stdout","time":"2021-01-06T22:03:50.227561763Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.ShapedQueryCompilingExpressionVisitor.SingleOrDefaultAsync[TSource](IAsyncEnumerable`1 asyncEnumerable, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.227569921Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.ShapedQueryCompilingExpressionVisitor.SingleOrDefaultAsync[TSource](IAsyncEnumerable`1 asyncEnumerable, CancellationToken cancellationToken)\n","stream":"stdout","time":"2021-01-06T22:03:50.227574247Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.HeartbeatService.RegisterAgentAsync() in /src/OpenAlprWebhookProcessor/HeartbeatService/HeartbeatService.cs:line 163\n","stream":"stdout","time":"2021-01-06T22:03:50.2275796Z"}
{"log":"Unhandled exception. Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such table: Companies'.\n","stream":"stderr","time":"2021-01-06T22:03:50.236620609Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)\n","stream":"stderr","time":"2021-01-06T22:03:50.236655309Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements(Stopwatch timer)+MoveNext()\n","stream":"stderr","time":"2021-01-06T22:03:50.236664189Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.GetStatements(Stopwatch timer)+MoveNext()\n","stream":"stderr","time":"2021-01-06T22:03:50.236668354Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()\n","stream":"stderr","time":"2021-01-06T22:03:50.236672334Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)\n","stream":"stderr","time":"2021-01-06T22:03:50.236676373Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T22:03:50.23668029Z"}
{"log":" at Microsoft.Data.Sqlite.SqliteCommand.ExecuteDbDataReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T22:03:50.236684664Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T22:03:50.236688759Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T22:03:50.236692957Z"}
{"log":" at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T22:03:50.236697028Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.Internal.QueryingEnumerable`1.AsyncEnumerator.InitializeReaderAsync(DbContext _, Boolean result, CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T22:03:50.236702455Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.Internal.QueryingEnumerable`1.AsyncEnumerator.MoveNextAsync()\n","stream":"stderr","time":"2021-01-06T22:03:50.236709712Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.ShapedQueryCompilingExpressionVisitor.SingleOrDefaultAsync[TSource](IAsyncEnumerable`1 asyncEnumerable, CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T22:03:50.236714806Z"}
{"log":" at Microsoft.EntityFrameworkCore.Query.ShapedQueryCompilingExpressionVisitor.SingleOrDefaultAsync[TSource](IAsyncEnumerable`1 asyncEnumerable, CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T22:03:50.236733645Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.HeartbeatService.RegisterAgentAsync() in /src/OpenAlprWebhookProcessor/HeartbeatService/HeartbeatService.cs:line 163\n","stream":"stderr","time":"2021-01-06T22:03:50.236739783Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.HeartbeatService.StartAsync(CancellationToken cancellationToken) in /src/OpenAlprWebhookProcessor/HeartbeatService/HeartbeatService.cs:line 45\n","stream":"stderr","time":"2021-01-06T22:03:50.236744137Z"}
{"log":" at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)\n","stream":"stderr","time":"2021-01-06T22:03:50.236748439Z"}
{"log":" at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)\n","stream":"stderr","time":"2021-01-06T22:03:50.236752384Z"}
{"log":" at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)\n","stream":"stderr","time":"2021-01-06T22:03:50.236757803Z"}
{"log":" at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)\n","stream":"stderr","time":"2021-01-06T22:03:50.236764009Z"}
{"log":" at OpenAlprWebhookProcessor.Program.Main(String[] args) in /src/OpenAlprWebhookProcessor/Program.cs:line 21\n","stream":"stderr","time":"2021-01-06T22:03:50.236769964Z"}
appsettings.json:{
"AllowedHosts": "*",
"OpenAlprAgent": {
"Cameras": [
"Latitude": 11.1111,
"Longitude": -11.1111,
"Manufacturer": "Dahua",
"Name": "<redacted>",
"OpenAlprCameraId": <redacted>,
"Password": "<redacted>",
"UpdateOverlayTextUrl": "http://10.200.200.14/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].CustomTitle[1].Text=",
"Username": "admin"
"Hostname": "<redacted>",
"OpenAlprWebServer": {
"Endpoint": "https://10.200.200.54",
"IgnoreSslErrors": true,
"Username": "<redacted>",
"Uid": "<redacted>",
"Version": "2.8.101"
"ConnectionStrings": {
"ProcessorContext": "Data Source=config/processor.db"
"WebRequestLoggingEnabled": false
{"log":"[00:19:43 WRN] 'AddEntityFramework*' was called on the service provider, but 'UseInternalServiceProvider' wasn't called in the DbContext options configuration. Remove the 'AddEntityFramework*' call as in most cases it's not needed and might cause conflicts with other products and services registered in the same service provider.\n","stream":"stdout","time":"2021-01-07T00:19:43.194916538Z"}
{"log":"[00:19:44 INF] Entity Framework Core 3.1.10 initialized 'ProcessorContext' using provider 'Microsoft.EntityFrameworkCore.Sqlite' with options: None\n","stream":"stdout","time":"2021-01-07T00:19:44.847164497Z"}
{"log":"[00:19:44 INF] Entity Framework Core 3.1.10 initialized 'ProcessorContext' using provider 'Microsoft.EntityFrameworkCore.Sqlite' with options: None\n","stream":"stdout","time":"2021-01-07T00:19:44.863075257Z"}
{"log":"[00:19:45 INF] Executed DbCommand (53ms) [Parameters=[], CommandType='Text', CommandTimeout='30']\n","stream":"stdout","time":"2021-01-07T00:19:45.549152314Z"}
{"log":"SELECT COUNT(*) FROM \"sqlite_master\" WHERE \"name\" = '__EFMigrationsHistory' AND \"type\" = 'table';\n","stream":"stdout","time":"2021-01-07T00:19:45.549226531Z"}
{"log":"[00:19:45 INF] Executed DbCommand (3ms) [Parameters=[], CommandType='Text', CommandTimeout='30']\n","stream":"stdout","time":"2021-01-07T00:19:45.7281065Z"}
{"log":"SELECT \"MigrationId\", \"ProductVersion\"\n","stream":"stdout","time":"2021-01-07T00:19:45.728250314Z"}
{"log":"FROM \"__EFMigrationsHistory\"\n","stream":"stdout","time":"2021-01-07T00:19:45.728266499Z"}
{"log":"ORDER BY \"MigrationId\";\n","stream":"stdout","time":"2021-01-07T00:19:45.72827383Z"}
{"log":"[00:19:49 INF] Now listening on: http://[::]:80\n","stream":"stdout","time":"2021-01-07T00:19:49.191138483Z"}
{"log":"[00:19:49 INF] Application started. Press Ctrl+C to shut down.\n","stream":"stdout","time":"2021-01-07T00:19:49.191733723Z"}
{"log":"[00:19:49 INF] Hosting environment: Production\n","stream":"stdout","time":"2021-01-07T00:19:49.191851566Z"}
{"log":"[00:19:49 INF] Content root path: /app\n","stream":"stdout","time":"2021-01-07T00:19:49.192033424Z"}
{"log":"[00:19:49 INF] Executed DbCommand (12ms) [Parameters=[@__companyId_0='?' (Size = 36)], CommandType='Text', CommandTimeout='30']\n","stream":"stdout","time":"2021-01-07T00:19:49.199837846Z"}
{"log":"SELECT \"c\".\"Id\", \"c\".\"CompanyId\", \"c\".\"Username\"\n","stream":"stdout","time":"2021-01-07T00:19:49.199877661Z"}
{"log":"FROM \"Companies\" AS \"c\"\n","stream":"stdout","time":"2021-01-07T00:19:49.199888853Z"}
{"log":"WHERE \"c\".\"CompanyId\" = @__companyId_0\n","stream":"stdout","time":"2021-01-07T00:19:49.199896729Z"}
{"log":"LIMIT 1\n","stream":"stdout","time":"2021-01-07T00:19:49.199905205Z"}
{"log":"[00:19:49 INF] Agent registered with server successfully\n","stream":"stdout","time":"2021-01-07T00:19:49.293842784Z"}
{"log":"[00:23:12 INF] Request starting HTTP/1.1 POST http://<redacted>3859/webhook application/json 10615\n","stream":"stdout","time":"2021-01-07T00:23:12.392537004Z"}
{"log":"[00:23:12 INF] Executing endpoint 'OpenAlprWebhookProcessor.WebhookProcessor.WebhookController.Post (OpenAlprWebhookProcessor)'\n","stream":"stdout","time":"2021-01-07T00:23:12.6599716Z"}
{"log":"[00:23:12 INF] Route matched with {action = \"Post\", controller = \"Webhook\"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.ActionResult] Post() on controller OpenAlprWebhookProcessor.WebhookProcessor.WebhookController (OpenAlprWebhookProcessor).\n","stream":"stdout","time":"2021-01-07T00:23:12.747761278Z"}
{"log":"[00:23:12 INF] request received from: ::ffff:54.221.95.194\n","stream":"stdout","time":"2021-01-07T00:23:12.960773736Z"}
{"log":"[00:23:13 INF] adding job for plate: LUBY12\n","stream":"stdout","time":"2021-01-07T00:23:13.017100345Z"}
{"log":"[00:23:13 INF] processing job for plate: LUBY12\n","stream":"stdout","time":"2021-01-07T00:23:13.017772634Z"}
{"log":"[00:23:13 INF] Entity Framework Core 3.1.10 initialized 'ProcessorContext' using provider 'Microsoft.EntityFrameworkCore.Sqlite' with options: None\n","stream":"stdout","time":"2021-01-07T00:23:13.157217654Z"}
{"log":"[00:23:13 INF] Executed DbCommand (3ms) [Parameters=[@p0='?', @p1='?', @p2='?', @p3='?', @p4='?', @p5='?', @p6='?' (Size = 3968), @p7='?' (Size = 6), @p8='?'], CommandType='Text', CommandTimeout='30']\n","stream":"stdout","time":"2021-01-07T00:23:13.606864078Z"}
{"log":"INSERT INTO \"PlateGroups\" (\"Id\", \"AlertDescription\", \"IsAlert\", \"OpenAlprCameraId\", \"OpenAlprProcessingTimeMs\", \"PlateConfidence\", \"PlateJpeg\", \"PlateNumber\", \"ReceivedOn\")\n","stream":"stdout","time":"2021-01-07T00:23:13.606912726Z"}
{"log":"VALUES (@p0, @p1, @p2, @p3, @p4, @p5, @p6, @p7, @p8);\n","stream":"stdout","time":"2021-01-07T00:23:13.606925341Z"}
{"log":"[00:23:13 INF] Executing HttpStatusCodeResult, setting HTTP status code 200\n","stream":"stdout","time":"2021-01-07T00:23:13.709508959Z"}
{"log":"[00:23:13 INF] Executed action OpenAlprWebhookProcessor.WebhookProcessor.WebhookController.Post (OpenAlprWebhookProcessor) in 963.6327ms\n","stream":"stdout","time":"2021-01-07T00:23:13.727908106Z"}
{"log":"[00:23:13 INF] Executed endpoint 'OpenAlprWebhookProcessor.WebhookProcessor.WebhookController.Post (OpenAlprWebhookProcessor)'\n","stream":"stdout","time":"2021-01-07T00:23:13.732339531Z"}
{"log":"[00:23:13 INF] HTTP POST /webhook responded 200 in 1339.3447 ms\n","stream":"stdout","time":"2021-01-07T00:23:13.74294483Z"}
{"log":"[00:23:13 INF] Request finished in 1378.8405ms 200 \n","stream":"stdout","time":"2021-01-07T00:23:13.759276868Z"}
{"log":"[00:23:19 INF] clearing expired overlay for: 254963574\n","stream":"stdout","time":"2021-01-07T00:23:19.157631745Z"}
appsettings.json and make sure I didn't misconfigure something there.Endpoint field then wait for it to push something there{"log":"[00:23:13 INF] HTTP POST /webhook responded 200 in 1339.3447 ms\n","stream":"stdout","time":"2021-01-07T00:23:13.74294483Z"} so there's probably just something wrong with the payload{"log":"[02:28:44 WRN] 'AddEntityFramework*' was called on the service provider, but 'UseInternalServiceProvider' wasn't called in the DbContext options configuration. Remove the 'AddEntityFramework*' call as in most cases it's not needed and might cause conflicts with other products and services registered in the same service provider.\n","stream":"stdout","time":"2021-01-07T02:28:44.154195089Z"}
{"log":"[02:28:44 ERR] failed to register Agent\n","stream":"stdout","time":"2021-01-07T02:28:44.851420118Z"}
{"log":"System.Net.Http.HttpRequestException: \u003c!DOCTYPE html\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851467585Z"}
{"log":"\u003chtml lang=\"en\"\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851482557Z"}
{"log":" \u003chead\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851490684Z"}
{"log":" \u003cmeta charset=\"utf-8\"\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851498397Z"}
{"log":" \u003cmeta name=\"viewport\" content=\"width=device-width, initial-scale=1\"\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851505907Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.8515152Z"}
{"log":" \u003ctitle\u003eNot Found\u003c/title\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851522052Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.851529395Z"}
{"log":" \u003c!-- Fonts --\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851535371Z"}
{"log":" \u003clink rel=\"dns-prefetch\" href=\"/fonts.gstatic.com\"\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.85154156Z"}
{"log":" \u003clink href=\"https://fonts.googleapis.com/css?family=Nunito\" rel=\"stylesheet\"\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851549198Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.851556417Z"}
{"log":" \u003c!-- Styles --\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851562272Z"}
{"log":" \u003cstyle\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851571311Z"}
{"log":" html, body {\n","stream":"stdout","time":"2021-01-07T02:28:44.851577758Z"}
{"log":" background-color: #fff;\n","stream":"stdout","time":"2021-01-07T02:28:44.851584229Z"}
{"log":" color: #636b6f;\n","stream":"stdout","time":"2021-01-07T02:28:44.851590515Z"}
{"log":" font-family: 'Nunito', sans-serif;\n","stream":"stdout","time":"2021-01-07T02:28:44.851599634Z"}
{"log":" font-weight: 100;\n","stream":"stdout","time":"2021-01-07T02:28:44.851605606Z"}
{"log":" height: 100vh;\n","stream":"stdout","time":"2021-01-07T02:28:44.851611078Z"}
{"log":" margin: 0;\n","stream":"stdout","time":"2021-01-07T02:28:44.851616832Z"}
{"log":" }\n","stream":"stdout","time":"2021-01-07T02:28:44.851622639Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.85162987Z"}
{"log":" .full-height {\n","stream":"stdout","time":"2021-01-07T02:28:44.851635434Z"}
{"log":" height: 100vh;\n","stream":"stdout","time":"2021-01-07T02:28:44.851640859Z"}
{"log":" }\n","stream":"stdout","time":"2021-01-07T02:28:44.851646488Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.851652083Z"}
{"log":" .flex-center {\n","stream":"stdout","time":"2021-01-07T02:28:44.85165952Z"}
{"log":" align-items: center;\n","stream":"stdout","time":"2021-01-07T02:28:44.851665235Z"}
{"log":" display: flex;\n","stream":"stdout","time":"2021-01-07T02:28:44.851670804Z"}
{"log":" justify-content: center;\n","stream":"stdout","time":"2021-01-07T02:28:44.851676383Z"}
{"log":" }\n","stream":"stdout","time":"2021-01-07T02:28:44.851682031Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.851689829Z"}
{"log":" .position-ref {\n","stream":"stdout","time":"2021-01-07T02:28:44.851695262Z"}
{"log":" position: relative;\n","stream":"stdout","time":"2021-01-07T02:28:44.851716284Z"}
{"log":" }\n","stream":"stdout","time":"2021-01-07T02:28:44.851724776Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.851755262Z"}
{"log":" .code {\n","stream":"stdout","time":"2021-01-07T02:28:44.85176401Z"}
{"log":" border-right: 2px solid;\n","stream":"stdout","time":"2021-01-07T02:28:44.851770826Z"}
{"log":" font-size: 26px;\n","stream":"stdout","time":"2021-01-07T02:28:44.851779329Z"}
{"log":" padding: 0 15px 0 15px;\n","stream":"stdout","time":"2021-01-07T02:28:44.851785724Z"}
{"log":" text-align: center;\n","stream":"stdout","time":"2021-01-07T02:28:44.851791894Z"}
{"log":" }\n","stream":"stdout","time":"2021-01-07T02:28:44.851797675Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.851805239Z"}
{"log":" .message {\n","stream":"stdout","time":"2021-01-07T02:28:44.851810737Z"}
{"log":" font-size: 18px;\n","stream":"stdout","time":"2021-01-07T02:28:44.851817028Z"}
{"log":" text-align: center;\n","stream":"stdout","time":"2021-01-07T02:28:44.851822783Z"}
{"log":" }\n","stream":"stdout","time":"2021-01-07T02:28:44.851828935Z"}
{"log":" \u003c/style\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851836248Z"}
{"log":" \u003c/head\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851842619Z"}
{"log":" \u003cbody\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851848512Z"}
{"log":" \u003cdiv class=\"flex-center position-ref full-height\"\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851854698Z"}
{"log":" \u003cdiv class=\"code\"\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851861428Z"}
{"log":" 404 \u003c/div\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851867277Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.851873119Z"}
{"log":" \u003cdiv class=\"message\" style=\"padding: 10px;\"\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851878593Z"}
{"log":" Not Found \u003c/div\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.85188522Z"}
{"log":" \u003c/div\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851891026Z"}
{"log":" \u003c/body\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851897048Z"}
{"log":"\u003c/html\u003e\n","stream":"stdout","time":"2021-01-07T02:28:44.851902964Z"}
{"log":"\n","stream":"stdout","time":"2021-01-07T02:28:44.851909192Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.AgentRegistration.RegisterAgentAsync(Uri serverUrl, String username, String password, Boolean ignoreSslErrors) in /src/OpenAlprWebhookProcessor/HeartbeatService/Registration/AgentRegistration.cs:line 43\n","stream":"stdout","time":"2021-01-07T02:28:44.851915262Z"}
{"log":" at OpenAlprWebhookProcessor.HeartbeatService.HeartbeatService.RegisterAgentAsync() in /src/OpenAlprWebhookProcessor/HeartbeatService/HeartbeatService.cs:line 155\n","stream":"stdout","time":"2021-01-07T02:28:44.851924635Z"}
{"log":"[02:28:44 INF] Entity Framework Core 3.1.10 initialized 'ProcessorContext' using provider 'Microsoft.EntityFrameworkCore.Sqlite' with options: None\n","stream":"stdout","time":"2021-01-07T02:28:44.8603842Z"}
{"log":"[02:28:45 INF] Executed DbCommand (22ms) [Parameters=[], CommandType='Text', CommandTimeout='30']\n","stream":"stdout","time":"2021-01-07T02:28:45.092627329Z"}
{"log":"SELECT COUNT(*) FROM \"sqlite_master\" WHERE \"name\" = '__EFMigrationsHistory' AND \"type\" = 'table';\n","stream":"stdout","time":"2021-01-07T02:28:45.092663969Z"}
{"log":"[02:28:45 INF] Executed DbCommand (1ms) [Parameters=[], CommandType='Text', CommandTimeout='30']\n","stream":"stdout","time":"2021-01-07T02:28:45.134506171Z"}
{"log":"SELECT \"MigrationId\", \"ProductVersion\"\n","stream":"stdout","time":"2021-01-07T02:28:45.134571864Z"}
{"log":"FROM \"__EFMigrationsHistory\"\n","stream":"stdout","time":"2021-01-07T02:28:45.13458823Z"}
{"log":"ORDER BY \"MigrationId\";\n","stream":"stdout","time":"2021-01-07T02:28:45.134595917Z"}
{"log":"[02:28:45 INF] Now listening on: http://[::]:80\n","stream":"stdout","time":"2021-01-07T02:28:45.281662312Z"}
{"log":"[02:28:45 INF] Application started. Press Ctrl+C to shut down.\n","stream":"stdout","time":"2021-01-07T02:28:45.282610273Z"}
{"log":"[02:28:45 INF] Hosting environment: Production\n","stream":"stdout","time":"2021-01-07T02:28:45.282846314Z"}
{"log":"[02:28:45 INF] Content root path: /app\n","stream":"stdout","time":"2021-01-07T02:28:45.283198284Z"}
{"log":"[02:29:50 INF] Request starting HTTP/1.1 POST http://<REDACTED>3859/webhook application/json 10855\n","stream":"stdout","time":"2021-01-07T02:29:50.968258435Z"}
{"log":"[02:29:51 INF] Executing endpoint 'OpenAlprWebhookProcessor.WebhookProcessor.WebhookController.Post (OpenAlprWebhookProcessor)'\n","stream":"stdout","time":"2021-01-07T02:29:51.120180004Z"}
{"log":"[02:29:51 INF] Route matched with {action = \"Post\", controller = \"Webhook\"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.ActionResult] Post() on controller OpenAlprWebhookProcessor.WebhookProcessor.WebhookController (OpenAlprWebhookProcessor).\n","stream":"stdout","time":"2021-01-07T02:29:51.262028663Z"}
{"log":"[02:29:53 INF] request received from: ::ffff:35.170.81.143\n","stream":"stdout","time":"2021-01-07T02:29:53.033663398Z"}
{"log":"[02:29:53 INF] adding job for plate: LUBY12\n","stream":"stdout","time":"2021-01-07T02:29:53.040811725Z"}
{"log":"[02:29:53 INF] processing job for plate: LUBY12\n","stream":"stdout","time":"2021-01-07T02:29:53.043126732Z"}
{"log":"[02:29:53 INF] Entity Framework Core 3.1.10 initialized 'ProcessorContext' using provider 'Microsoft.EntityFrameworkCore.Sqlite' with options: None\n","stream":"stdout","time":"2021-01-07T02:29:53.056186075Z"}
{"log":"[02:29:53 INF] Executed DbCommand (11ms) [Parameters=[@p0='?', @p1='?', @p2='?', @p3='?', @p4='?', @p5='?', @p6='?' (Size = 3944), @p7='?' (Size = 6), @p8='?'], CommandType='Text', CommandTimeout='30']\n","stream":"stdout","time":"2021-01-07T02:29:53.439823167Z"}
{"log":"INSERT INTO \"PlateGroups\" (\"Id\", \"AlertDescription\", \"IsAlert\", \"OpenAlprCameraId\", \"OpenAlprProcessingTimeMs\", \"PlateConfidence\", \"PlateJpeg\", \"PlateNumber\", \"ReceivedOn\")\n","stream":"stdout","time":"2021-01-07T02:29:53.43987305Z"}
{"log":"VALUES (@p0, @p1, @p2, @p3, @p4, @p5, @p6, @p7, @p8);\n","stream":"stdout","time":"2021-01-07T02:29:53.439890127Z"}
{"log":"[02:29:53 INF] Entity Framework Core 3.1.10 initialized 'ProcessorContext' using provider 'Microsoft.EntityFrameworkCore.Sqlite' with options: None\n","stream":"stdout","time":"2021-01-07T02:29:53.57166309Z"}
{"log":"[02:29:53 INF] Executed DbCommand (1ms) [Parameters=[@___agentConfiguration_OpenAlprWebServer_Username_0='?' (Size = 22)], CommandType='Text', CommandTimeout='30']\n","stream":"stdout","time":"2021-01-07T02:29:53.986242915Z"}
{"log":"SELECT \"c\".\"Id\", \"c\".\"CompanyId\", \"c\".\"Username\"\n","stream":"stdout","time":"2021-01-07T02:29:53.986287562Z"}
{"log":"FROM \"Companies\" AS \"c\"\n","stream":"stdout","time":"2021-01-07T02:29:53.986304643Z"}
{"log":"WHERE \"c\".\"Username\" = @___agentConfiguration_OpenAlprWebServer_Username_0\n","stream":"stdout","time":"2021-01-07T02:29:53.986313853Z"}
{"log":"LIMIT 1\n","stream":"stdout","time":"2021-01-07T02:29:53.986320263Z"}
{"log":"[02:29:54 INF] Executing HttpStatusCodeResult, setting HTTP status code 200\n","stream":"stdout","time":"2021-01-07T02:29:54.541791463Z"}
{"log":"[02:29:54 INF] Executed action OpenAlprWebhookProcessor.WebhookProcessor.WebhookController.Post (OpenAlprWebhookProcessor) in 3280.8168ms\n","stream":"stdout","time":"2021-01-07T02:29:54.554349608Z"}
{"log":"[02:29:54 INF] Executed endpoint 'OpenAlprWebhookProcessor.WebhookProcessor.WebhookController.Post (OpenAlprWebhookProcessor)'\n","stream":"stdout","time":"2021-01-07T02:29:54.558171031Z"}
{"log":"[02:29:54 INF] HTTP POST /webhook responded 200 in 3586.9490 ms\n","stream":"stdout","time":"2021-01-07T02:29:54.564168969Z"}
{"log":"[02:29:54 INF] Request finished in 3619.9942ms 200 \n","stream":"stdout","time":"2021-01-07T02:29:54.571667345Z"}
{"log":"[02:29:58 INF] clearing expired overlay for: 254963574\n","stream":"stdout","time":"2021-01-07T02:29:58.990527255Z"}
