OpenALPR Webhook Processor for IP Cameras
when you upgrade it's going to switch over to the new authentication method, your user will be deleted and you'll need to recreate one when you reload the page. other than that nothing you need to do!
Is the payload that the agent send via data destination(to their cloud server or local webserver) the same you receive via webhooks?
Yes, I actually have my agent sending data directly to the app, bypassing rekor's website.
I
I tried installing it on my windows machine and it is giving me an error with the database.
Edit: Here is the log:
Microsoft Windows [Version 10.0.26100.4946]
(c) Microsoft Corporation. All rights reserved.
C:\OpenAlprWebHookProcessor-v6.0.2-windows64>dotnet ./OpenAlprWebhookProcessor.dll
Could not execute because the specified command or file was not found.
Possible reasons for this include:
* You misspelled a built-in dotnet command.
* You intended to execute a .NET program, but dotnet-./OpenAlprWebhookProcessor.dll does not exist.
* You intended to run a global tool, but a dotnet-prefixed executable with this name could not be found on the PATH.
C:\OpenAlprWebHookProcessor-v6.0.2-windows64>dotnet ./OpenAlprWebhookProcessor.Server.dll
[09:40:33 INF] User profile is available. Using 'C:\Users\Xeon\AppData\Local\ASP.NET\DataProtection-Keys' as key repository and Windows DPAPI to encrypt keys at rest.
[09:40:34 INF] SimpleCameraScheduler hosted service starting
[09:40:34 INF] Starting simple camera scheduler
[09:40:34 INF] Resetting all cameras to correct day/night mode
[09:40:34 WRN] The query uses the 'First'/'FirstOrDefault' operator without 'OrderBy' and filter operators. This may lead to unpredictable results.
[09:40:34 ERR] Failed executing DbCommand (2ms) [Parameters=[], CommandType='Text', CommandTimeout='30']
SELECT "c"."Id", "c"."CameraPassword", "c"."CameraUsername", "c"."DayFocus", "c"."DayZoom", "c"."IpAddress", "c"."LatestProcessedPlateUuid", "c"."Latitude", "c"."Longitude", "c"."Manufacturer", "c"."ModelNumber", "c"."NextClearOverlayScheduleId", "c"."NextDayNightScheduleId", "c"."NightFocus", "c"."NightZoom", "c"."OpenAlprCameraId", "c"."OpenAlprEnabled", "c"."OpenAlprName", "c"."PlatesSeen", "c"."SunriseOffset", "c"."SunsetOffset", "c"."TimezoneOffset", "c"."UpdateDayNightModeEnabled", "c"."UpdateDayNightModeUrl", "c"."UpdateOverlayEnabled", "c"."UpdateOverlayTextUrl"
FROM "Cameras" AS "c"
WHERE "c"."UpdateDayNightModeEnabled"
[09:40:34 ERR] Failed executing DbCommand (13ms) [Parameters=[], CommandType='Text', CommandTimeout='30']
SELECT "w"."Id", "w"."IsEnabled", "w"."PrivateKey", "w"."PublicKey", "w"."SendEveryPlateEnabled", "w"."Subject"
FROM "WebPushSettings" AS "w"
LIMIT 1
[09:40:34 ERR] An exception occurred while iterating over the results of a query for context type 'OpenAlprWebhookProcessor.Data.ProcessorContext'.
Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such table: Cameras'.
at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)
at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements()+MoveNext()
at Microsoft.Data.Sqlite.SqliteCommand.GetStatements()+MoveNext()
at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()
at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)
at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)
at Microsoft.Data.Sqlite.SqliteCommand.ExecuteDbDataReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)
at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteReaderAsync(RelationalCommandParameterObject parameterObject, CancellationToken cancellationToken)
at Microsoft.EntityFrameworkCore.Query.Internal.SingleQueryingEnumerable`1.AsyncEnumerator.InitializeReaderAsync(AsyncEnumerator enumerator, CancellationToken cancellationToken)
at Microsoft.EntityFrameworkCore.Query.Internal.SingleQueryingEnumerable`1.AsyncEnumerator.MoveNextAsync()
Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such table: WebPushSettings'.
[09:40:34 ERR] SimpleCameraScheduler hosted service encountered an error
at Microsoft.EntityFrameworkCore.EntityFrameworkQueryableExtensions.ToListAsync[TSource](IQueryable`1 source, CancellationToken cancellationToken)
at OpenAlprWebhookProcessor.Data.Repositories.Repository`1.FindAsync(Expression`1 predicate, CancellationToken cancellationToken) in /home/runner/work/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor.Server/Data/Repositories/Repository.cs:line 35
at OpenAlprWebhookProcessor.CameraUpdateService.SimpleCameraScheduler.ResetAllCamerasAsync(CancellationToken cancellationToken) in /home/runner/work/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor.Server/CameraUpdateService/SimpleCameraScheduler.cs:line 90
at OpenAlprWebhookProcessor.CameraUpdateService.SimpleCameraScheduler.StartAsync(CancellationToken cancellationToken) in /home/runner/work/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor.Server/CameraUpdateService/SimpleCameraScheduler.cs:line 47
at OpenAlprWebhookProcessor.CameraUpdateService.SimpleCameraSchedulerHostedService.ExecuteAsync(CancellationToken stoppingToken) in /home/runner/work/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor.Server/CameraUpdateService/SimpleCameraSchedulerHostedService.cs:line 27
[09:40:34 INF] WebsocketClientOrganizerHostedService cancellation requested
System.Threading.Tasks.TaskCanceledException: A task was canceled.
at OpenAlprWebhookProcessor.Features.Webhooks.WebhookProcessor.OpenAlprWebsocket.WebsocketClientOrganizerHostedService.ExecuteAsync(CancellationToken stoppingToken) in /home/runner/work/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor.Server/Features/Webhooks/WebhookProcessor/OpenAlprWebsocket/WebSocketClientOrganizerHostedService.cs:line 31
[09:40:34 INF] HydrationHostedService starting...
[09:40:34 INF] Disconnecting all websocket clients...
[09:40:34 INF] Disconnecting all 0 websocket clients
[09:40:34 INF] All websocket clients disconnected
[09:40:34 ERR] An error occurred using the connection to database 'main' on server 'config/processor.db'.
[09:40:34 FTL] Host terminated unexpectedly
at Microsoft.EntityFrameworkCore.Storage.RelationalConnection.OpenInternalAsync(Boolean errorsExpected, CancellationToken cancellationToken)
at Microsoft.EntityFrameworkCore.Storage.RelationalConnection.OpenAsync(CancellationToken cancellationToken, Boolean errorsExpected)
at Microsoft.EntityFrameworkCore.Query.ShapedQueryCompilingExpressionVisitor.SingleOrDefaultAsync[TSource](IAsyncEnumerable`1 asyncEnumerable, CancellationToken cancellationToken)
at OpenAlprWebhookProcessor.Data.Repositories.AgentRepository.GetFirstAgentAsync(CancellationToken cancellationToken) in /home/runner/work/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor.Server/Data/Repositories/AgentRepository.cs:line 15
at OpenAlprWebhookProcessor.Hydrator.HydrationService.ScheduleHydrationAsync(CancellationToken cancellationToken) in /home/runner/work/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor.Server/Hydration/HydrationService.cs:line 74
at OpenAlprWebhookProcessor.Hydrator.HydrationHostedService.ExecuteAsync(CancellationToken stoppingToken) in /home/runner/work/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor.Server/Hydration/HydrationHostedService.cs:line 40
at Microsoft.Extensions.Hosting.Internal.Host.<StartAsync>b__14_1(IHostedService service, CancellationToken token)
at Microsoft.Extensions.Hosting.Internal.Host.ForeachService[T](IEnumerable`1 services, CancellationToken token, Boolean concurrent, Boolean abortOnFirstException, List`1 exceptions, Func`3 operation)
at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
at OpenAlprWebhookProcessor.Program.Main(String[] args) in /home/runner/work/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor/OpenAlprWebhookProcessor.Server/Program.cs:line 72
@mlapaglia Amazing work... how long could it take to load up all data...?
Upgrade on docker container was seamless..
My previous 5.3.0 Db size : )
Data is loading up.. kid in a candy store seeing all the new features and enhancements you have made..
I am starting from scratch on a whole new VM
What user does the container run as? Wondering what the permissions should be like for the config folder
Not sure what I'm doing wrong really, I set 777 permissions on the folder for now, just so no matter what, it could write. Got logged in and I can save settings etc, so clearly that works
However, pushover will fail to test right away, even though it has the same settings as my old install which works fine
The agent also will not start, despite having the exact same settings. It fails instantly like it never tries and gives this in the log
13:11:13 INF] Request finished HTTP/1.1 POST - 400 null application/problem+json; charset=utf-8 4.4812ms
Any ideas? New UI looks AWESOME.
Well, I guess nevermind. Just got the email from Rekor that they are increasing the price to $12/mo per camera. I though the jump to $10/mo per camera was already too high, just had not got around to looking into alternatives
$12/mo just is unacceptable IMO, cancelled the subscription
Reactions: Vettester
Need some help.
I upgraded openalprwebhookprocessor to 6.2.2 (from 5.0.0). This is running in a docker container. I update the docker config to use port 8080. I created my new login, I am able to login & view my all of my historical license plates.
My problem is that the OpenALPR agent now shows disconnected. And I am not sure how to get it reconnected. If I click on Scrape to try to pull the latest license plates, it says "Scrape Finished", but in the docker container logs it shows the below.
[17:47:40 INF] Request starting HTTP/1.1 POST - null 0
[17:47:40 INF] CORS policy execution failed.
[17:47:40 INF] Request origin does not have permission to access the resource.
[17:47:40 INF] Executing endpoint 'OpenAlprWebhookProcessor.Features.Settings.SettingsController.StartScrape (OpenAlprWebhookProcessor.Server)'
[17:47:40 INF] Route matched with {action = "StartScrape", controller = "Settings"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] StartScrape(System.Threading.CancellationToken) on controller OpenAlprWebhookProcessor.Features.Settings.SettingsController (OpenAlprWebhookProcessor.Server).
[17:47:40 INF] Starting OpenALPR Agent scrape. Request: hydration, Pending: 0
[17:47:40 INF] Executing StatusCodeResult, setting HTTP status code 202
[17:47:40 INF] Executed action OpenAlprWebhookProcessor.Features.Settings.SettingsController.StartScrape (OpenAlprWebhookProcessor.Server) in 12.8197ms
[17:47:40 INF] Executed endpoint 'OpenAlprWebhookProcessor.Features.Settings.SettingsController.StartScrape (OpenAlprWebhookProcessor.Server)'
[17:47:40 INF] HTTP POST /api/settings/agent/scrape responded 202 in 24.8033 ms
[17:47:40 INF] Request finished HTTP/1.1 POST - 202 0 null 25.4367ms
[17:47:40 INF] Scraping between 1758403549676 and 1758489949676
[17:47:40 INF] Start processing HTTP request GET [17:47:40 INF] Sending HTTP request GET [17:47:43 INF] Received HTTP response headers after 2750.0979ms - 200
[17:47:43 INF] End processing HTTP request after 2758.6447ms - 200
[17:47:43 INF] Scraping took 2 seconds
[17:47:43 INF] Found 0 entries for: 1758489949676
[17:47:43 INF] Finished OpenALPR Agent scrape.
[17:47:43 INF] Searching for plates with missings images
[17:47:43 INF] Found 0 plates to query the Agent for.
[17:47:43 INF] Jobs added successfully.
[17:47:43 INF] OpenALPR Agent scrape completed successfully
Oh boy, looks like we have an upgrade!! is this a seamless process, I am still on version 5.3.0
Second question for today! I used to run the overlay text display on my 49225 PTZ without issues, should this also work on a IPC-B54IR-Z4E-S3 bullet, appears not to be at the moment after I enable 'custom title' on said camera. Guessing maybe a different setup on the newer cameras, or possibly an incorrect setting which I have missed most likely.
I would still like to know if anyone has the text overlay running on a IPC-B54IR-Z4E-S3 bullet camera, if so what script/command they are using. :thumb:
*****Update, just resolved this. In camera Overlay I enabled 'Location' then used the normal script/command:
http://cam_ip_address/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].CustomTitle[1].Text=
Working fine now on the S3 bullet.
Need some help.
Did you ever figure this out? My agent also won't connect
Did pretty much similar with hik anpr camera, listener for events and isapi for osd change, works really good. Hik also have option to apply thumbnail image inside video, so you can ecen attach few KB plate thumbnail
