Yes and basically their p2p ecosystem was vulnerable. They issued major changes (like killing SmartPSS) and FW updates summer of 2024 to alleviate it and their P2P now goes with AWS servers
I don't knowAt that age it is probably the vulnerable P2P servers that Dahua shut down and Lorex didn't?
We have a wonderful AT&T Wi-Fi gateway, they don't offer a modem only, at least in our area. Did I mention we have VERY little options for internet?L term you're going to get off Lores cloud.
Ask your provider to supply a modem, just a modem, with pass thru capabilities and you'll control your own network with your own router.
Buy a mid level Asus that has built in OpenVPN and WireGuard and use one of those VPNs for remote access
www.asus.com
IP Passthrough is what ATT calls it
Configuring Arris BGW-210 For “Bridge Mode” or IP Passthrough: Use Your Own Router
This was originally posted on Reddit by BinaryDichotomy Many of us have AT&T Fiber internet service (aka Gigabit internet), and as such have the Arris BGW210-700 Gateway (herein further referre…juicytool.wordpress.com
Look over the routers and make sure the one you choose has WireGuard VPN (Its faster and less hassle than OpenVPN)
I'm not a networking/router expert. But I'd probably go with the RT-AX88U-Pro fwiw
ASUS WiFi Routers - All Models|WiFi Routers|ASUS USA
In ASUS 「ASUS WiFi Routers - All Models」 - Networking / IoT / Servers , you could find most appropriate Networking / IoT / Servers based on product features, specification or price. And you also could get product's detail information and comparsion, even add it into the wish list in buy page.www.asus.com
You would think you could use the site search function or even the good old page search (CTRL + F) to locate anything to do with WireGuard, but nope and it's buried 1/2 way down the product page under advanced VPN. NOT very intuitive as far as I'm concerned. One must go through ALL models to verify if it has the feature.
Scroll and look harder Luke. Use the Force
Either way, the model you suggest is out of my budget currently - especially after buying a shitload of cameras. And it seems a little overkill for what I need especially with the speeds AT&T provides to our modest 1100 sq ft home. I would have to keep it under $150 when I do purchase.
I get what you are saying, but I am at a disadvantage since my knowledge of network security and VPNs are very sparse and/or outdated. It's easy to get frustrated when you don't have a grasp on the subject. I also don't have the budget for the recommended device at the current time, so I either wait or find a device that will do the job within my budget.Do what you want. Personally I won;t cheap out on security of most any kind.
You dont have to do anything. Keep doing what you're doing
Welcome
I think every Asus router has either their version of a VPN or OpenVPN and certainly one within your budget.
This one has their Instant-Guard VPN
www.asus.com
