NVR608RH-32-XI Dropping Frames in Continuous Recording. Need Help to Fix This Issue.
I dont have your NVR but I'm not sure that you can.
You know how to go directly to the camera GUI itself and get them right?
I don’t even know how to do that on DMSS?
For snapshots under the schedule, should I select General & Intelligent or just Intelligent? Also, when I play back footage under Search, I always have to uncheck the AI Rule box to remove the AI rule lines from the screen. How can I disable them permanently, but still have the option to enable them again if needed? I don’t want them to appear by default when I go to search and playback. It’s so annoying.
As I show on picture - both...
General is for 24/7 recordings, Inteligent for all AI events..
Did you watch YouTube video which I give you twice with NVR tutorial?
