Notes from the Swamp
My old car alarm that I installed back in 1975 had a motion sensor that you wired in. I think it was a mercury switch like they had in the old time Honeywell house thermostats. It was adjustable for how much motion would trigger it. I bet you could find one on Amazon.
Stooopid bastid almost hit it again with the stern when he goosed the throttle and steered hard to starboard.
It IS against the law to be piloting a boat in FL when intoxicated, right? Is there any kind of marine patrol -type LEO on that waterway?
Being in the Mobile Electronics for many years one of the reasons I used cameras so much was my stores.. Motion sensor and Mercury sensor were a couple of different things.. Normally motion was either air change from cabin pressure and or beam sensors that detected changes in the reflections with in an area. Mercury was more for tilting for anti jacking or one would mount on hood and trunk for detection if they were opened.. There are some others that came later that was great for DEI called a proximity sensor where you could leave your windows down and if someone reached into your car or even got close without touching it, it would do a warn away, You are to close to the vehicle move away then if you reached in the car it would go off.. Then people that lived on hills could have issues with Mercury switches because of the hill so then adding in just a switch was better for that however required drilling a hole in the area for the switch to be installed..
