I’m using Edge.Browser likely.
What are you using? Edge or Edge in IE mode should work, as should Pale Moon 32
Ok, I might be trying to get into them the wrong way. I log into the NVR and then click the blue e in the bottom of the camera to access it. Would it be the internet or the plug in? I have 1gig fiber.I just got in 4 of mine with the new GUI with plain Edge and was able to view the live video
Sometimes its simply close browser, start over. Unfortunately camera FW can be ornery
Man, I feel so stupid, it was the plug in. It works now. I’m sorry to bother y’all. This is all a new learning process for me. Now I’m going to try to do some settings with the picture and then get it on DMSS.The blue ie on the camera registration page of the NVR. Show a pic
4k-t180 for my side overview of the house. I still have two more cameras to install which are the S3. That will be for the front of the house. I need to more cameras than these but having to start off with these and then add more along the way. I’m new to all of this and pretty excited to go away from WiFi cameras and have Poe cameras. Just a learning curve for me.No worries
What model camera?
Yes sir. Thanks again for your help and everyone’s else too.I would have started with one of the single lens cameras, but oh well. Dont get too bogged down, learn the basics before you try to fly the plane
Gnite
No, mine just has the copy where yours has the setting.Under Storage Schedule in the NVR does your page look like this? click on the event type in this case IVS and then click and drag on the screen to change from not with a line to one with a line?
Ok, I will try that later today. ThanksSorry you are correct. This should be better to what you are working with.. Drag the line on IVS copy to the rest of the days bottom right copy to the channels you want setup the same way. Will also want to make changes to your snapshot in same way..
Good Day
