Can you post screenshot of ipconfig from your Blue Iris server as well?
Did find a setting I didn't know was there saying "Repair Database" do you think this may help?
The router shouldn't be between the NVR and BI server, just acting as a switch if configured normally
If you're using DHCP your IP addresses could have changed.
The DHCP configuration is in your router not BI. Your cameras should all have a static IP address. If you're not going to post your camera's video configuration there's not much we can help you with.
Ok so your BI server is on the 192.168.1 subnet and your cameras are on the 192.168.254 subnet which means they cannot talk directly so I'm guessing your NVR is 192.168.1.101 and they were pulling the cameras through that address so something on the NVR must have changed to cause this issue not the cameras or BI server.
What IP is the NVR currently using? If it is set to use DHCP for the NVRs IP then it likely switched from 101 to something else and according to your screenshot from your BI server it looks like it was setup on that side for 192.168.1.101 originally so if the NVR IP did change you would want to modify your routers DHCP settings to either reserve 192.168.1.101 for the NVR or change the DHCP scope to assign addresses from 109-254 only so that you can then change the NVR not to use DHCP but statically assign it 192.168.1.101 again.
Assuming your router will let you change its subnet you could log into your router from your BI server and change it to use the 192.168.254 subnet. If you have a static IP on your BI server this will have to be changed as well.
Thanks, glad I caught this before changing and then possibly makeing it another challenge to be able to get online even!Can you show the video settings for one of the BI cameras that you haven't changed since this issue started?
