fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,408
Lighting helps A LOT! I would advise against motion activated because it will cause the camera to go into day mode from night mode which screws the image for a second or two during the change...you can use the schedule to change it night mode during the evening but a better solution is dawn to dusk lights on full time..if you have a switch that controls it use a regular dual head fixture and this switch which uses your gps coordiates to adjust relative to sunrise sunset.
http://www.amazon.com/gp/product/B004AP92N2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Use led bulbs (dont get the spot ones, get a flood that spreads the light, the spots will be too bright and wash out faces and only focus on one area, it may be hard to find outdoor led floods (cree makes one with a wider beam than its normal outdoor spot) but i use indoor damp rated bulbs out side with no issues)
While its always good to have ambient light, another option is to add more IR..there is a thread about various models...wrightwood sells a particularly good one for about 60...
Finally, you may want to consider one of these hikvisions http://www.ipcamtalk.com/showthread.php?1413-New-Hikvision-Bullets-DS-2CD2T32
You can choose ir strength up to 80m (30, 50 or 80 are the options)...the 2mp has the widest angle of view i think....
