Mike A.
- May 6, 2017
- 4,209
- 7,097
Only records or only triggers? Two different things but triggering is what will cause it to record assuming that you're not recording continuous.
In any case, motion is using BI's motion detection not that from the cam. If you only want triggers from the cam, then you'd run only with ONVIF checked. You also need the box checked under Video > Configure > Get ONVIF trigger events to have BI pick up the ONVIF triggers.
