jimnycricket65
How 5442-ZE powered? My house is wired for internet. In theory can I run a long cable to the front yard plugged into a poe port?
 Not sure what you mean here?Any update to the system + camera?
I presume you need one of those DVR/Brain units with the POE capabilities.
I wonder if a wire mesh system port will work. I will update you once I get that far. And, If 12vdc works, I can connect to a front yard outlet which is used for Xmas lights.It is powered by POE or 12VDC.
But yes you could simply run an outdoor rated ethernet cable to it as long as the total run is under 300 feet or so.
Thanks, I got a good sense. I want one or two LCR on my lawn hidden in a wooden box like yours. I don't know which cam will actually work the best. I will order a sample and connect it to my Wire Mesh satellite port --> poe switch --> to CAM to see if it will power it up. Do any of your cam work without "the controller/harddrive/brain" unit? Can the camera connect to your network and use your networked PC to capture License plates driving by?Not sure what you mean here?
I run BlueIris on a dedicated PC. My 20+ cams are all POE cams and are powered with POE switches. I have four POE switches to run those cams.
See this thread for how I installed the LPR cams.
LPR Case Study: Scoping, Planning, Proof of Concept, Installation, & Results
Introduction This thread is about my journey into LPR (License Plate Recognition) after having about 18 months of experience with IP cams and having quite a bit of my system finished. I am not an expert on LPR, or IP cameras either. But I have spent a lot of time working with my system and...ipcamtalk.com
This is what I do not understand...brain unit? No idea what you are talking about."the controller/harddrive/brain" unit?
yes, NPR. Do I need NPR for Model 5442-ZE which was recommended by a forum member.This is what I do not understand...brain unit? No idea what you are talking about.
To get a better understanding of how cams work, check out the WIKI.
In the future, it would be good to use the terminology that can be found in the WIKI when asking for help.Do any of your cam work without "the controller/harddrive/brain" unit? Can the camera connect to your network and use your networked PC to capture License plates driving by?
I got my unit and plugged them all in and went through the settings. The npr kept beeping. After listening to it some time, I found an alarm for missing a hard drive. The fan noise is pretty loud for me to keep it running at my home office. Does the fan go on and off I wonder.
If you are storing to internal 10TB hard drives, why would you want to push it up to cloud storage? That is a LOT of data being pumped out of your home LAN. Could overwhelm your router/modem and go over your allotment with your IP provider.Is there away to upload directly to Google Storage or iCloud? Has this been addressed?
Thank you!
