New Reolink Wired POE Doorbell Cam ?
Is this the recommended PoE doorbell camera? Mine just died, and it was using power from the doorbell transformer.
Yes, it was a pain to run Ethernet but the doorbell has been rock solid.
Reactions: 105437
Yes $90 good price
There are two versions, one wide the other narrow lens...
Reactions: 105437
Yes, either chose the POE (wired, preferred) version or the wireless version ( is dual band but uses existing doorbell xfrmr power of 12-24V AC 50/60Hz, or DC 24V
power).
Also choose white or black depending on desired aspect ratio (horiz to vert ratio).
Here's the comparison chart:
power).
I appreciate the reply. I’m going to definitely go with the PoE version. Is the black one vertical orientation?
Reactions: TonyR and David L
The white is 135 vert and 100 horiz.
The black is 100 vert and 135 horiz.
I just updated that post with the compare chart :cool:
Reactions: 105437
I have the black one which is wider than the white
Reactions: 105437
I’m going to need the vertical aspect ratio. Since it’s white, I’ll probably paint it with PlastiDip to look better in my case.
I just went out and measured from the stone you see on the left to the adjacent wall. 6 feet.
So the lens starts at about 5 feet wide
HTH
Reactions: 105437
Are you using the wedge mount? That’s really helpful, thanks!
No. But if you see the stone on the left, I do get IR reflection from it, need to wedge it some to get past the stone. But I have watched countless videos at night and it does not stop good images of people walking up...so I have just left it alone.
If it were me, I would order both POE versions, maybe from Amazon, then return the one that does not work for you. Or both, if ReoLink has a better price...
I bought the first version from ReoLink when it first came out, then bought the WiFi version from Amazon a few months later. I was hoping to go POE but I would of had to cut out a bunch of sheetrock to get the Ethernet cable down since they stapled the existing power doorbell wires. Both houses :confused: , our new house same thing, would need to cut out sheetrock, wife said NO...:lmao:
The WiFi is working great so I am ok. Access Point is all the way on the other side of the house, 3 walls and front door away. Still get 2 bars...and no signal loss
Maybe I will wedge some to get more IR on the wall side...but when the IR reflects off of people I see them fine...I will add it to my todo list :)
But almost forgot, we have a motion porch light that comes On so IR shuts off when people approach...which only happens on a blue moon out here in the country...
Ordered the white one from Amazon. They are supposed to send me an email once it's available. I'm hopeful the vertical orientation works out for my FOV. If not, I can return it and get the black version.
Reactions: David L
Found my post here when I first installed the Reolink at our old house:
Reactions: 105437
Guys, I finally received the camera from Amazon. I ordered the white one and it took a while to get here. Anyway, the camera is installed and working as expected with the Reolink app on my phone. However, it won't add to BI. Is there a trick or setting I need to change to successfully add it to BI. Here's the message I get when I do a find/inspect using the camera credentials. Thanks!
Reactions: David L
Looks like you need to enable RTSP in the Reolink app:
On the Reolink app, click on the Settings, then on the camera name, then Network Information, then Advanced, and turn on all the optional features:
Reactions: David L and 105437
Thanks! That was the issue. Is there a way to change the Key Frame in the Reolink app camera settings? This is what I'm getting right now. I'd like the Key Frame to match FPS, 20. Much appreciated!
Can someone pinpoint for me the last firmware that allows the two-way communication to work. I have seen people say it works, but I cannot get it to work. I went back a forth with Support a little and they suggested a firmware broke the feature, but didn't know which one.
I have been trying to use two-way with the app and I can hear the camera's audio, but no talking back through the camera.
That’s the firmware version I’m using and it works great.
v3.0.0.3215_2401272070
