New Reolink Wired POE Doorbell Cam ?
Wonder if there is something ReoLink did to the newer DBs to stop third party Chimes
they changed the frequency from 433 to 900 MHz, supposedly longer reach it's obvious they didn't want 3rd party chimes.. this wouldn't be so bad, i mean they have their right to close their system if they want, but they don't offer additional chimes.. if you want one you pretty much have to purchase a new doorbell :(
oh and, if you want to buy another doorbell to have a second chime, make sure you buy with the right chime either v1 or V2.
Reactions: David L
I just saw the posts about 3rd party chimes. I have successfully paired two of the below chimes from Amazon. Slight issue with one of them, it will not save the chime sound when I try to change it, keeps reverting back to the siren. My Reolink firmware is v3.0.0.2033_23041300, hardware DB_566128M5MP_W . (I didn't use the doorbell button that came with the Amazon kit)
did your camera came with the chime v2 originally or with the chime v2?
Uh oh. This Reddit thread suggests that the newer Reolink doorbells units are now using 900 MHz RF to connect to chimes, linking out to this Home Assistant thread with more details:
Anyone know how my two units' reported "Hardware No. DB_566128M5MP_P" from the Reolink web UI maps to this version number?
here is my HW info, and i confirm that mine came with a chime 2 and does not work with the programable 433 MHz chimes
fenderman, who has successfully paired with 3rd-party, 433 MHz chimes, reports DB_566128M5MP_P, which is the same as mine, which is the same as yours, except for the trailing P/W, which I assume is for POE/WiFi.
I hope this isn't one of those frustrating situations where a company changes the hardware, but doesn't change the reported hardware ID.
Is Chime v2 visibly different from the previous chime? How does one tell?
Reactions: David L
Interesting, I bought exactly the same KERUI chimes and got the same HW version that you have (DB_566128M5MP_W ).... but i am failing miserably to pair them... i think i'm doing the right process, pushing the volume and + buttons together to make it enter into the program mode, i can delet and re-add their transmiter, but not the reolink doorbell....
am I doing something wrong?
otherwise, could you please confirm if the doorbell was paired with a reolink chime V1 or a v2? i am wondering what makes the difference, for the doorbell to transmit... maybe it is the chime that was last paired to it? because it seems like my reolink is transmitting at 433 mhz...
it could also be the firmware, Mine has the v3.0.0.3215_2401262240 ... wondering if that's it... alas i have nowhere from where to get that FW to test :(
the label of the chime says "Hardware V2" in my chime:
I did a little sleuthing and googled for "reolink FCC", which returns a list of their recent filings, and then looked at every filing since late 2022. The filings don't have the model in the title, but I found two filings for doorbells (by looking at the External Photos) and then opened their Test Reports text-searched for "MHz:"
The Sep. 28, 2022 Test Report from their 2022-12-15 filing (Final Action Date) lists an Operation Frequency of 433.92MHz:
whereas the 2024-03-11 report from their 2024-03-21 filing lists an Operation Frequency of 915 MHz:
So this is consistent with them changing the chime frequency and locking out 3rd-party chimes.
It's not proof, but it's corroborating evidence.
edit: Hah. I didn't even have to look that hard. The header of each filing shows the frequency range:
Reactions: aesterling
LOL, i wonder if it is our fW version... or maybe once you have a chime paired to it, it will transmit on that frequency.. and if you pair two (one old and one new) it will transmit in both? :p
Nope. That's why I'm here. :facepalm:
The Sep. 28, 2022 report lists an Operation Frequency of 433.92MHz:
whereas the 2024-03-11 report lists an Operation Frequency of 915 MHz:
WOW, man you really are a detective! :) great job!
Alas, I would for now accept this as valid proof :( I think this pretty much confirms that there are two versions under the same HW model they are listing, and only one frequency operates on each version.
this means that even if your cam fails, if you get a new one, chances are even your very reolink chime will not work with the new one :(
well that settles it....
i guess now it's up to our hardworking electronic friend to come up with some circuit to connect to the 24 chime but instead of using 433Mhz, using a 915MHz receiver...
perhaps this one with an Arduino, or maybe this one is closer to the solutions that already are out there?
they changed the frequency from 433 to 900 MHz, supposedly longer reach.....
One would think 433MHz would have a longer reach than 900/915 MHz, much like 2.4GHz does better than 5GHz when Line Of Sight is not optimum. :idk:
Reactions: gabrielcr78
POE Version Firmwares:
WiFi Version Firmwares:
