flynreelow
- Dec 12, 2016
- 1,588
- 1,462
u get your doorbell today?Just got email today also @ 3:13 pm Pacific with the tracking , should be here saturday.
Yes, just got it about hour ago.u get your doorbell today?
no rain in sight... just gonna be a bit chillyYes, just got it about hour ago.
I also need to figure out about the cable must go quite way, three walls to get to the front door.
Hopefully weather is good for next weekend to do it.
Yap looks promising! No rain and temp goes up a little, that's nice to work outdoors.no rain in sight... just gonna be a bit chilly
nice, cant wait to see how it turns out.Yap looks promising! No rain and temp goes up a little, that's nice to work outdoors.
Last week i run 2 cat6 cables from office (upstairs) to master upstairs and living room down stairs so i can add a sec. asus router for backhaul mesh system, just have to buy it soon maybe when it goes in sale. And ya was raining too, but got wet too , wife said no more work in the rain. Anyway hopefully will manage next week end to get this installed.
its only 7pm... u got hours more to get this goin in BI?Well just an update...
Got the cable installed took about 1.5 hour and then the video door bell holes in the door trim and hole in the side.
Installed it into the app @ riolink and all went well.
Now when adding at the BI No matter what i do i can get the stream to start.
Done for today but will still be checking this out and other settings i guess to make it work with BI as all my cam's are there.
From help.
"RTSP “keep alives” are reply packets sent occasionally to the camera. Most cameras either
require them or tolerate them. In rare cases, these “break” the stream and will cause
continuous re-connects each 20-30 seconds."
There is no difference in performance as Neolink uses the proprietary Reolink protocol. Audio source can be anything in theory.
Imagine that, Reolink is one of the rare cases where normal RTSP keep alive packets break a device. Obviously none of us are surprised! Reolink developers are clearly a cut BELOW the rest.
Please keep us updated on your progress and use case! I haven't looked over that information yet, but I can definitely see where this could be useful!
Imagine that, Reolink is one of the rare cases where normal RTSP keep alive packets break a device. Obviously none of us are surprised! Reolink developers are clearly a cut BELOW the rest.![]()
I got mine over this past weekend. I did try to connect to it via a POE injector to my laptop. So far no go, I am trying to see if I can bypass the App. On there site they say they come with an IP and you can use their Windows Client to connect to it. But mine is not seeing it. Still playing with it, a little at a time, been real busy. Pretty much won't be able to touch it until next week.anyone else get theres?
do we know when Reolink will restock these?
U can see the ip with "Advanced ip scanner"...I got mine over this past weekend. I did try to connect to it via a POE injector to my laptop. So far no go, I am trying to see if I can bypass the App. On there site they say they come with an IP and you can use their Windows Client to connect to it. But mine is not seeing it. Still playing with it, a little at a time, been real busy. Pretty much won't be able to touch it until next week.
Have not heard of restock yet.
Introduction to the Default IP Address of Reolink Cameras and NVRs
All Reolink cameras and NVRs with Ethernet interface are allocated a default IP Address when they came out from the factory. ...support.reolink.com
How to Initially Set up Doorbell PoE via Reolink Client
If you want to initially set up your Doorbell PoE camera via Reolink Client, please scroll down for a step-by-step guide. Ste...support.reolink.com
Merry Christmas all...
how do u like it so far?U can see the ip with "Advanced ip scanner"...
My door bell is connected into a poe+ network hub with all other cameras.
I like Reolink better than one fromhow do u like it so far?
the NSC-DB2 one for sure.![]()
3MP Wi-Fi Video Doorbell ONVIF Compliant IP Camera with 2 Way Audio, PIR Motion Sensor, Night Vision, 16GB SD Card Pre-Installed, and 3 Face Plates (NSC-DB2)
Video Doorbell Camera delivering 3MP of crisp clear video Dual Band Wifi (2.4Ghz / 5GHz) to reach all types of routers and wireless access points PIR Motion Detection to detect true human movement. Much less false motion events than standard pixel based motion. Clear Night Vision up to 16' -...www.nellyssecurity.com
I have it connected in BI with all my other cameras.
Not that i know. yet.any issues so far? i take it you are recording 24/7 and have set up alerts in BI for motion, line crossing, etc?
Thanks will try it, I like the fact it is portable. I tried (arp -a) in a cmd window but since neither my laptop or the Reolink is not connected to a router it did not work.U can see the ip with "Advanced ip scanner"...
All roelink cameras , mac starts with: EC:... So i easy to find the ip, even in your wireless router under 192.168.1.1
