Do you know if more than one wireless chime can be added?I received the POE version last week and added it to BI. I haven't had time to install it at the front door, but it appears to be working so far laying on the basement floor. I'm only using the main stream currently. It's my first Reolink product so we'll see how it works.
please keep us postedI received the POE version last week and added it to BI. I haven't had time to install it at the front door, but it appears to be working so far laying on the basement floor. I'm only using the main stream currently. It's my first Reolink product so we'll see how it works.
Did you get the email that it was delayed to December? Just wondering if that was a generic email and I could receive it early or if you ordered way ahead of me and got in the first batch to be sent out. Thanks for the information on it working so far.I received the POE version last week and added it to BI. I haven't had time to install it at the front door, but it appears to be working so far laying on the basement floor. I'm only using the main stream currently. It's my first Reolink product so we'll see how it works.
Still haven't received mine.any update to this doorbell? any full review from members
I agree with you that POE is the best choice, especially if I want to have a 24/7 stream, even if it's a sub stream. It doesn't feel right to deviate from my "all-POE setup".POE is the better choice. WiFi isn’t great. The WiFi version can use an Ethernet cable if WiFi doesn’t work according to Reolink support, it just can’t be powered by POE on the WiFi version. You could still use a POE splitter at the cable end if you can hide it somewhere so you can feed power to the bullet connector.
Most people I have seen just run new cable near the door where possible and rather than put it in the door frame itself simply place it next to the door, then wood dust/wood glue fill the holes from the old doorbell and paint over them. You could even tuck it along the bottom edge of the wall if it’s brick from a garage if necessary, then run it along the door frame then caulk and paint over it.I agree with you that POE is the best choice, especially if I want to have a 24/7 stream, even if it's a sub stream. It doesn't feel right to deviate from my "all-POE setup".I need to find a way to hide the CAT6 though. It doesn't seem to be much space to pull out the cable from behind the doorbell so I guess I need to drill a hole in the wood panel and try to run the cable on the inside of the panel somehow.
Technically you could connect the WiFi version via POE Ethernet and a POE splitter that then powers the doorbell also.Received my POE Reolink Doorbell today. Some bad news (at least so far) is that the current firmware does not allow fixed frame rate with iframe setting to 1. When added to BI it has an iframe that is variable and shows 0.5 and the substream has iframe of 0.25. Image quality looks pretty good compared to my Lorex 2k.
One confusing thing prior to install is that it has screw terminals for connection to existing doorbell wiring but the FAQ says:
Can I use Reolink Video Doorbell PoE with my pre-existing chimes?
No, Reolink Video Doorbell PoE does not work with chimes of other brands.
Well...here goes nothing. Gonna fish me a CAT6 cable, terminate, and install the existing doorbell wires as well. Hopefully I don't fry my doorbell or the Ubiquiti 24 port switch!
PS - the quick start guide appears to show the Wifi version still having a LAN port but mentions you need to power through existing doorbell wiring. That might be an interesting option for some??
