Also, I thought that maybe the issue with Home assistant was that the surveillance center checkbox was not checked, but I cannot seem to be able to configure motion. I am unable to check any boxes
Would you be willing to share what you did to get the motion sensor exposed to Home Assistant?So I got the Laview version of the doorbell today. Initially I had some trouble getting it connected to wifi through the app, but I eventually got it to work through AP mode. I upgraded the firmware to the latest (v5.2.4 190716) and ONVIF is working great. I can get ONVIF motion detection events from the camera's PIR and all is working as expected. I've actually written a small Python script to get these motion events into Home Assistant as well.
Has anyone found a way to track the actual doorbell button presses without using the app/cloud?
Thanks, I was trying to move the date to a different area of the screen and see now that even though it moves in the configuration screen, it only will show in the bottom center of the screen.
Do any of the firmwares have an option to turn off the outside ring?
Hey guys, to those who have owned both, would you recommend the Hikvision Gen 1 or 2 doorbell?
Gen 2 $130 worth double the Gen 1 at $70 today?![]()
I like the stealth branding on the Nelly's as well, but ended up going with RCA because it was a bit cheaper and they didn't offer a bronze face plate.Update: The Nelly's version gets just as hot. I do like that is has no branding on it besides the plastic wrap that has a nelly's tag.
Two Questions on the RCA HSDB2.
+ What would be the connection string used in Blue Iris to connect to the Doorbell? I had this working and for some reason, it stopped and having difficulties getting it working again.
+ Is there other software than the RCA App. Find this app terrible, need to sign in every time after an update and miss half the people at the door.
Is there one thats preferred? Does anything need to be done to the camera first, like firmware?You have several choices of phone Apps, EZVIZ, LaView ONE, Hik-Connect, etc. I think there is one or two more but I can't recall their names.
What's the connection string for getting the camera set up in Blue Iris?
It seems people here do like the LaView ONE App, but some also like the EZVIZ App, they are very similar. Only thing I have read here is you may need to remove/unregister your Doorbell from the RCA App first, but I would first try to install one or both and see if they find your Doorbell.
I know this thread is big but there are plenty of messages about this same subject so if you run into any issues you are in the right place. You cannot mess up anything by trying other Apps and you do not have to upgrade your firmware either to try other Apps.
But as far as your firmware but pretty much all of the RCA owners here has upgraded to either LaView's firmware or Nelly's for the ONVIF support. This I can help you with, just let me know. Also by upgrading your RCA, with the firmware mentioned you will be able to remove that big RCA Logo you see in your view screen
As for your last question, I have not yet setup Blue Iris to help you with the config. I believe that if you have a firmware with ONVIF then Blue Iris should enter all the parameters for you, not sure though.
Maybe this will help:
RTSP streams:
rtsp:/[email protected]:554/Streaming/Channels/101/ - Main Stream
rtsp:/[email protected]:554/Streaming/Channels/102/ - Sub Stream
or
rtsp:/[email protected]:554/ch1/main/av_stream
rtsp:/[email protected]:554/ch1/sub/av_stream
Just replace the $ with :
enter your Doorbells IP with the :554 port number
admin will be username
password is the verification code off of the back of your Doorbell (mine was 6 capital characters long, ex. XYZZYX)
Also:
You can view the RTSP stream in VLC under Media/Open Network Stream...
One more suggestion, install the Hikvision Configuration Batch Tool
If you upgrade your firmware this is the software you need. Also you can change a lot of things on your camera like brightness, frame rate (FULL FRAME) is 30FPS, you can also get to the files of your SD Card on the camera and copy them to your PC. Great Tool to have.
I know this message is long, sorry just trying to think of everything that will help you. I will search for some screenshots in this thread for your Blue Iris Config.
UPDATE: I found one message with a screenshot of Blue Iris: message #1,023
There are more but let me know if this works for you first before I search for more, thanks.
Thank you very much for the great explanation & info!
Yes, I would be interested in the firmware upgrade.
+ Is there a recommended one to install (LaView or Nelly's)? Also a location to download?
I plan to use the LaView One App once the firmware is updated.
Those were the parameters I originally had. The RCA doorbell is connected to WiFi. I get notifications via RCA, but I think the WiFi might be low strength causing BI not to connect.
Thank you! I was able to get the camera firmware upgraded and also reconnected to Blue Iris. Your screenshot helped and I also had to adjust my firewall rules on PFSense. After moving it to a separate IoT network it would help if I created a rule.
I was able to download and get an account created for the Laview ONE app. It seems like the only way you can add a device is by QR code or SN. Is there another way to add my RCA doorbell would I need to scan a code on the doorbell itself?
Found the QR code on the RCA packaging and that worked. Wow, this app seems better already as long as I don't have to login anymore for answering.
Thanks again for your help, think I'm set!!
