flynreelow
- Dec 12, 2016
- 1,616
- 1,485
All Video DBs have their small form factor limits.I do have a separate PoE camera with a larger IMX347 1/1.8" sensor as well, running PoE to my doorbell is a nono lol.
The Reolink Doorbell quality is fine if you have sufficient lights but still has it's limitation due to its form factor
There is or use to be a setting in the App (EZVIZ) where you can encrypt your video, don't remember any encryption with Images.I just noticed all my EZVIZ images are stored publicly, with no encryption or login. I know there was a massive uproar when Eufy didn't encrypt stuff, but I suppose that's because they promised encryption. EZVIZ doesn't mentioned anything about encryption. Just seems bizarre to me that all images would be stored on a public server.
I suppose people know about this because the URLs are built into third party integrations (like in Home Assistant etc).
Can I disable this? I'm happy to VPN into my network if I need to see images. I still want it to act as a doorbell though so don't want to block all Internet connectivity.
There are several options to get off their cloud. The one I use(d) is using Home Assistant with Blue Iris. Having the Home Assistant App running on our phones, we get notifications when someone was at our door. No 2 way Talking though...I run a local VPN Server that our phones connect to. Oh one more thing with EZVIZ, in order to get doorbell button press notifications, normally a relay with usually Z-Wave/Zigbee will be needed. Many here came up with different options which you can find in our 101
HTH
I personally try to stay away from clouds. I did use the EZVIZ App when I had my LaView DB (Hik/DB1 variant) but now with ReoLink I do not use their Cloud/App.Thanks David, I think I have encrypted video, it's just all our images being stored on a public server that makes no sense to me. I had assumed that logging into the app would authenticate me to access images/video from the doorbell itself (or at least access it from a restricted cloud server).
I know a lot of people seem to have migrated go Reolink, do we know if they have a sane cloud architecture?
I would prefer not to set up a relay for doorbell rings, there's only so much tech debt a household can take on I already run stuff via Home Assistant, it's just doorbell notifications are a key missing piece there that requires the app.
Hi. Anyone knows where I can buy internal li-po battery for hikvision ds-hd1?
This one?just put that money towards the Reolink POE doorbell.
thats the wifi version if you cant use POE for the doorbell.This one?
REOLINK Doorbell WiFi Camera - Wired 5MP Outdoor Video Doorbell, 5G&2.4G WiFi Security Camera System, Smart Detection Local Storage No Subscription Front Door Camera Is it that much better?
Just installed it. I liked hikconnect app way better. There was notification tab and you can see all thumbnails of the events. And if you needed to play them back you just click on it. This reolink app doesn't provide same friendly no clutter convenient interface... you can only scroll from left to right so you only see a little bit. Where in hik connect they are presented vertically, and of course lots of the events fit vertically on the phone...Other than that seems fine so far. I connected it to the doorbell wires.thats the wifi version if you cant use POE for the doorbell.
and yes, its the best doorbell on the market.
My Hikvision DB is still working fine. (RTSP and ONVIF)
Can you provide a link to the battery?
While the PIR is still active my preference is to utilize an external outdoor PIR.
The chime is working fine connected to the alarm panel with a debounce circuit board and a current sensor board.
No. You need 3 wires, 3 pin flat connector.
Thank you. When you get it installed and working I will include your post in our 101...No. You need 3 wires, 3 pin flat connector.
This is what I ordered:
You'll also need to detach temp sensor from the top of the existing battery (it's just lightly glued), it has 2 pin connector. And put it on a new battery. Mine hasn't arrived yet..
TLDR: Unbricking via TTL Serial was successful!
I was able to get connected with the TTL Serial adapter, and found that the Config file of the camera is what is causing it not to load. The magic bullet was to interrupt the boot and issue a format command to erase everything but the bootloader, then issue an update command (with sdcard inserted, having RCA firmware renamed to digicap.dav as the only file present). This loaded successfully and the doorbell booted to a blue flashing ring and voice prompt to configure via phone app.
[/CODE]
