I tried finding Feit, where they are getting their Cams, are they Hikvision, Dahua, etc. Since they are not on any list I have found, the RTSP URL is the key to communicating with your DM Cam.Pete you still around?
No not saying that at all. Since BI was able to communicate to your DB tells us it is using either ONVIF or RTSProtocol Again the key is to have the correct RTSP URL, that goes for any Cam. or a Cam that supports ONVIF.Thanks for all the research. Are you saying I'm SOL? Just not sure why one works?
I guess I jinxed myself. Now it only seems to work occasionally. The notification that there was motion detected works 100% all of the time. I'll keep fiddling with it.
Which App are you guys using?Im also with this problem. Did you ever find any sollution? I have all setting enabled. Even draw before others is enabled. Still I only get a notification in Android 10 and it Never rings. It did ring on android 9...
Just to chime in. Both the wife and I have S20+ phones, I would say it improved for us from our S7 phones. Not by much, but we get rings around 80% of the time now, where it was, at times, 60-70% of the time before. We got our new phones, end of last year...Still believe this is still a cloud issue since it is random though. Problem too is few people no a days press the button. No Delivery people do anymore...this was hit or miss on my android phone as well.
It's the EZVIZ app 5.0.16.0709 and few versions before that combined with a Fairphone 3 (we have two of them) running Android 10. With Android 9 it all works perfect. With android 10 it will only give the skype call when the app is open. When the app is not open it will give a notification that someone range the door. When clicking this notification the skype sound will start. Again all settings are on allow, battery optimization is turned of, location, mic, etc etc, is all allowed, even show in front of other app and change system settings is allowed. The notification happens 100% of the time. Thats not the problem. But since the sound is the same short sound as the rest you have no idea someone is at the door when im at work. A text sounds the same. It surprises that soo little people post about this problem with Android 10. Only the one I quoted did and made a partial fix by enabling location etc. This enabling didnt work for me at all. Only the notification will happen.Which App are you guys using?
From our 101:
CONFIGURING DOORBELL TIPS:
⦁ Available Apps (Allows Remote Access):
iO/S: Hik-Connect, RCA Security, EZVIZ, LaView One, Guarding Vision
Android: Hik-Connect, RCA Security, EZVIZ, LaView ONE, Guarding Vision
⦁ Android 9 Hik-Connect Setup Help - Dewcal
⦁ In App be sure and change Hi-Def to Ultra HD
Hello all, I have an LTN8708-p8 NVR. Will this doorbell work?
It may but I do not see ONVIF support so unless I missed it would not be my 1st choice. It can still record but would not detect onvif cam triggers. Check for firmware update, it WAS not working with Win10 64bit when it first came out. I would hold off and see if some one has one to give you feed back before getting it. Just my 2cents. ONVIF is a big deal for me when it comes to cams but not always needed. Depends on the cams and if you need more then just recording.
Thanks, can you please explain the benefit of ONVIF? I have 3 dome cameras for recording only and just wanted a doorbell that can detect motion and I can also record and answer the ring.
My current NVR has motion detection, It sends notifications its built in software as well as the hik-connect app. Is that the same thing?
