KC8DKT
This is out of line and out of control!
1. the power kit is required for mechanical chimes.
2. these doorbells are not designed for lower then 12 volts you should be running 12v, it's designed for a normal doorbell transformer. not sure if 24v was ever considered spec for this doorbell. the doorbell does run hot on 12v I can validate that.
Yep, your right, "is out of line and out of control!" because I NEVER said the power kit should NOT be used to ANYONE! I never said the power kit was the problem to anyone that is dealing with this new problem where multiple chimes stopped working in the same month.
Some doorbells list the min volts at 12vac but the RCA lists it at 10vac and some one else posted the pdf pic of the spec sheet NOT ME showing this!
So again, if anyone has a problem with some thing I DID TYPE or DID TELL SOME ONE TO DO let me know and we can talk about that, but it is total BS to say and argue about some thing I did not EVERY type/tell anyone they should do.
Shitting razer blades would be a huge pain in the butt. I am stating a fact, I never said I was doing it and I never said some one should do it.
I do not think I have even 1 post with anyone about this new problem with the chimes that stopped working all in the same month for multiple people as he is implying. Not much I can do about some one getting pantry's in a twist about something I did not type, or when I take the step to state as clear as I can be so no one takes it the wrong way but if he reads something more into it well not much I can do about that. You can call a friend all kinds of stuff in voice comes in a game with no problem (tone of voice is joking) but that same thing in a TXT msg / forum / email and so on some people take it the wrong way. I know MOST IF NOT ALL have dealt with this and I did my best to make sure NO ONE WOULD TAKE IT THAT WAY as best I could. If that was not enough sorry, I did my best to make it as clear as I could. And like the last time he had a problem, I asked him to let it go back then and asked him again to let it go or at least keep it out of the open forum. Have no clue what more I can do.
. I had Laview firmware v190716 installed. Opened the EZVIZ Android app (it's worked quite well so far) and it informed me that there was a firmware upgrade - 200904. Now, I'm not entirely sure how the EZVIZ app alerted me to an updated Laview firmware. Anyhow, I clicked the Upgrade button in the EZVIZ app. Now both the EZVIZ app and BatchConfig report 200904 is installed. I probably should have just upgraded with Batch Config.
