alexdelprete
Getting comfortable
Also have one Tripp Lite here. Tripp Lite UPS's are made in Chicago, IL. Haven't had any issues with it.
You have almost everything that has ever been produced in IT. Your house must be a sort of datacenter.
Correct. I've not tried others apps than Guarding Vision on Android thought.So Android can't find the camera on the WLAN after the synthetic voice says it connected?
Yes. And I can add it manually to the app by referring to the IP address.Did you verifiy on the router/ap that the camera got an ip address and it is actually connected?
It answers ping.When the camera connects to the network, when you start app on the mobile to configure it again, it should find it almost immediately. Try to ping it from your pc to the address shown on the router (.14).
When I did the firmware install as per the steps you describe here - I did the config reset as per step 3.Regarding the firmware upgrade, you didn't answer to my second question: did you RESET the camera after the upgrade procedure?
No all on the same subnet no additional vlans. No internal firewall. I do have the wifi on both 2.4g and 5g, same SSID. I've tried once to turn off the 5g but still the same.Do you have the camera on a different subnet/vlan? Is there a fw between it and the wlan?
I see now I have a different version of batch config than you stated - is that important in this context?
Sorry to be a nuisance here:
Does anyone know how to ENABLE a frickin chime on the ezviz DB1..?
I don't see any option in the app, or guarding vision on iphone?
I just added a chime and there is no power to it. I'm sure it's wired correctly and my transformer is 24/40, so I'm not sure whats going on here? I saw an old post suggesting guarding, but see no option?
Is it the scotch, or..? lol
Hi:It is the scotch, for sure.
What mobile app are you using now? Install Guarding Vision app, when you see the camera, click on the hexagon icon next to it (options) and you will see the option for the chime type (electronic, mechanical, or disable).
If it works, I'll wait for a good bottle of old scotch, or a good canadian maple syrup for my pancakes.![]()
Ok, not sure if this was suggested but if so please disregard, this worked for me back when I first set my LaView DB up last year, I could not get past your point either until I connected 2.4, I had to turn temporally off my 5Ghz radio in my Asus router. Once past setup I turned 5 back on, even saw the DB connect at 5 since I had same SSID for both radios back then.Thanks. I've been using an iphone to try this multiple times and always failed in the second step, hearing the doorbell announce the configuration to be successful but the app timing out when reconnecting to the home wifi.
I found an old android and tried again using Guarding Vision but with exactly the same results.
I'm thinking if this has something to do with open or rather closed ports that are needed? I've kept upnp open on the router and see some ports being configured there on the IP of the doorbell. Could that be causing this?
Like you suggest, focusing on the configuration part - I expect that the firmware updates are not relevant as of now.
Well disregard my message, haha, I was too late in replying...Correct. I've not tried others apps than Guarding Vision on Android thought.
It answers ping.
He does haha, you ought to see his rackYou have almost everything that has ever been produced in IT. Your house must be a sort of datacenter.![]()
He does haha, you ought to see his rack![]()
Hi:
It goes deeper than that, I'm afraid.
I had the same problem another user had, not being able to use remote configuration on Guarding vision. It just says connection failed.
Then, the chime worked for about 3 minutes, but only if I DISCONNECTED the ezviz power doo-dad. Then it stopped STOPPING, and just kept ringing.
As soon as I reconnect the doo-dad, it doesn't ring the chime AT ALL.
I really have NO idea whats going ON with this thing. The chime is the Nu-Tone one that ezviz says is compatible, and I'm sure I have it wired correctly, so I don't know.
Hi:Get a multimeter and monitor what happens on the line when you press the button. If you don't see any change in values, then the doorbell is not activating the chime. If you see a difference in terms of voltages when you press the button, then the problem is how you connected everything. Did you install the power-kit? That is mandatory for chimes. Also, did you try the chime by itself to make sure it works? Power it up and check if it chimes. What transformer are you using?
Hi:
I'm using a 24V 40VA transformer. The chime is a Nutone LA600WH. When I put a multimeter on it, WITH the power kit, it shows no voltage. When I take the power kit OFF, it shows voltage, but the chime continuously chimes. The Chime DOES work by itself. Faulty power-kit?
I found someone else on this thread asking if anyone had ever got the LA600WH to work with the DB1, but no one answered him.
Another possibility is the gauge of wire I'm using, perhaps? I left it quite long and it may NOT be 18ga like the manufacturer states...I recall some reviewers commenting on this. When the power pack is attached or not, the doorbell still operates, but not the chime. I ordered a mechanical chime today from Amazon, that is known to work by another comment on here. Let's see if that works?
Hi:Transformer is ok, same specs I use. I don't think the power-kit is the problem. The chime should NOT chime continuously without it, IIRC, but there are people more knowledgable than me on the electrical part that might confirm or not. Did you choose "Electronic chime" in the option, right?
Gauge of the wire might be the issue, because in your case I suspect something's not working as it should, electrically. Let's see how it works with the mechanical chime. If the mechanical one works, probably the LA600WH doesn't work with our DB1.
Another thing you might try is opening a ticket with Ezviz support, if they declare the LA600WH is compatible, they should help solve your specific issue.
BTW, if you want Canadian Whiskey, I suggest you buy it where you are, in Rome. Every time I go to Europe they sell Canadian booze cheaper than we get it for, which is a real piss-off, if you can imagine.
Factoring in shipping, we must be getting ass-RAPED for alcohol here, no?
I tried everything to set it to the highest, but kept dropping out of BI. Not sure why. I suspect my connection. Only real explanation. 15fps seems to be the sweet spot. Waiting on another range extender to see if that will improve it. I also have a synology, but I'm debating on whether I should spend the $$ on yet another license for the camera. I may come back to you for synology setup. lolI use it at full frame, 25fps max, because it's configured in PAL mode, 50hz with a resolution of 2048*1536, with Synology Surveillance Station software. No issues here.
View attachment 70687View attachment 70688
The syrup or the whiskey? Are you Canadian?I was just joking, I prefer canadian maple syrup to canadian whiskey, but I can find it here luckily, a bit pricey, but very good.![]()
