Now I'm interested in uncompressing the firmware to see what goodies I can findMaybe, but what we have found, the firmware filenames seem to remain the same with each upgrade. They may have an Archive directory.
I agree. I emailed product support to get this implemented. Please email them as well - the more the better.
Yeah I too called LaView, did not get far, they would not let me talk to the Software Dept., as they called it. So never got past Tier 1 support, they pasted on my requestI've emailed them before about this same issue (both LaView and EZVIZ). I also emailed them to ask if it'd be possible to control the LEDs around the button from an ONVIF command or API call. I have them turned off permanently but I would love to be able to turn them on with an API call or even have them turned on automatically when the PIR detects motion. I don't want to leave them on all the time as they're super bright and visible at night. I'm using the Hikvision API to turn off the WDR during the day and then turn it back on at night, and I'd love to be able to do something similar with the LED ring!
Yeah I too called LaView, did not get far, they would not let me talk to the Software Dept., as they called it. So never got past Tier 1 support, they pasted on my request![]()
It's not that it showed and disappeared. It's the app showing all settings the app can do for ANY Hikvision cams but then narrows it down to what is supported by the specific camWould be awesome if you could figure out a way to alter them. Crazy but when we load Batch Config Tool, for a short burst you see all of the options removed...
Hmmm, loaded Batch Config Tool. The Remote Configuration are the same in both, only issue is iVMS-4200 sometimes does not show the CCD option I think that is one of the reasons most here use the Batch Tool, also it loads faster.
I can confirm that this camera also works with Eero mesh WiFi.
Thanks, just added to 101...It also works with the TP-Link mesh system. I use TP-Link Deco M9 Plus devices (3 of them cover a very wide area, outdoor spaces included).
Yes, though you posted a screenshot of IVMS, not Batch configuration tool. In the Batch Config app (screenshot I posted), there is no remote config option. Note that I am on a mac - don't know if another OS has a different version of the same tool.
@Pliable Pixels
I do not think that you are logged in to your Video Doorbell. That is why you are not able to change the settings using the Hikvision batch configuration program.
When you first install the Doorbell camera in the batch configuration program it'll ask you for the admin password and it will save it.
In fact you need to use the admin password with all of the aforementioned programs that run on Windows / Linux.
Batch Config tool is part of iVMS, or Ezviz Studio. You can also download it as a standalone tool from Hikvision's site. Same functions in all of them.
I confirm what David said: you can modify the volume in the video&audio settings, check attached screenshots.
View attachment 60610View attachment 60611
I don't know what OS everyone else is using - maybe a Windows or Linux app has more options than the mac? Works just fine with IVMS
Using Windows Server 2016 here for my Wintel apps via RDP.
I have iVMS for Linux that I have used for testing and it works fine.
Try install a Windows Virtual box on your Mac.
or try to reinstall it on your Mac.
I did not see this version on the 101, have any of you tried it yet?
I'll give it a try. Where is the download link?
Maybe the Lens, the DB has a Fisheye Lens which is not standard viewing...I had a 1st gen LaView doorbell and replaced it with an EZVIZ DB1after 2 year because it keeps disconnecting from the Guarding Vision app. I setup the Laview as a IP camera on my LTS HD-TVI DVR. Anyways, I was surprised that the 2nd gen does not have a web interface nor I can change the admin password. I tried adding it to my 5 yr old DVR and it's complaining that the 6 character password is risky. 2nd, it says parameters incorrect and won't display anything. After reading this thread, I downloaded the batch config tool and changed the resolution from 2048x1536 to 1280x960 since the max resolution supported by my DVR is 1080P. That worked but I'm wondering why they didn't have 1920x1080 on the drop down?
