Oh ... maybe a finger print smear on the len? You uploaded it to YouTube in 720p resolution so I couldn't tell you if it the camera or Youtube downgrading it.
When I view the Youtube video, it shows as 1440p. Video quality looks fine to me.
Looks like mine on a rainy day...It was maxed at 720p earlier. I check again and now I can view it at 1440p. Video seem fine to me too.
Do you remember if your Sage green wire (front) is tied with the white or black wire of the power kit?Don't use the fuse, that is to be used only if you have nothing. But you need to use the power kit. I followed the schema of the 101, instead of the chime you use the SAGE, connections are the same. In the app I configured an electronic chime. It works perfectly,
I connected Sage green with white power kit and the Sage white with black power kit and it wouldn’t work. The doorbell stop working once its’ internal battery is drained out
the chime wouldn’t work but EZVIZ app no longer have a setting to switch to chime so tomorrow I will try again and use Guarding Vision app to change chime setting
What would be a free or reasonable priced network tool/program that allows me to map my network for devices and their IP and or MAC addresses that would display in a flow chart or allow me to either capture the data so I can enter it in a network diagram chart. It has been many years since I used Visio, so looking for something along those lines. Also to be able add comment info like VLAN info per device.
Thanks
So our LaView has a "(W)" too. Our Doorbell faces West, just a guess, not sure if it is able to detect location like a GPS thoughThe flashing can be configured:
I noticed the OSD string of Joshwah ends on "(S)". My OSD string ends on "(W)". Does anybody know whats that about?
Isnt it summertime and wintertime as in daylight saving time?So our LaView has a "(W)" too. Our Doorbell faces West, just a guess, not sure if it is able to detect location like a GPS though
Maybe something to do with Timezone?
Josh, is from Australia, is it a regional tag? I live in the (USA) West
Thanks I will look at their products. I did see the "portable" label on your pic, that I like.I use SoftPerfect utilities for many things. One of those is WiFI Guard. Basically, when a device connects to my wifi, the scanner detects it and asks me if it is a known device, and I put a description of it to trace it. Once I acknowledge it as known device, it puts a green mark in the list. I like it because I can see the IPs, MAC addresses and what device it is.
Well I am wrong, as usual. You win a chicken dinner. It is DST. I found a Sept. post with mine showing a "S"Isnt it summertime and wintertime as in daylight saving time?
I followed this schema:
Here's a picture while I was testing it, you can see white on white and green on black:
Let me know if you need further help. It works. Keep in mind that the only problem I had was that if I turned off power to the doorbell, I had to remove sage battery, wait 5 secs, reinsert it. It needs a reboot after a power-down/power-up cycle. But that could depend also on the Hubitat driver for the SAGE I'm using
Let me know how it goes.
I finally got the chime working today. It turn out that the chime i brought was defective from the factory so I had to take it back to exchange it.
The power kit wires at the Y was just soldered wires and I clipped it off and twisted it with Sage Sensor then put a new terminal so it easier to screw it in. I have not yet pair it with hubitat since it still sitting on the floor in the attic. I plan to mount it in the hallway wall tomorrow.
It is required to set Chime in the doorbell setting and the recent update removed that. It wouldn't work at all so I had to download Guarding Vision to set the chime in the doorbell setting before it would start working. I wondered how ezviz managed to mess that one up so if anyone here want to hook it to chime will still need to enable in setting.
