Yes, I have a few versions older than that. I will upload them soon for you.
Here are the two that I have. I forget if I ever installed either of them.
HIKVISION DS-2TD1217-2-V1 Thermal Camera - iptcs_h3_en_std_5.5.18_191202
HIKVISION DS-2TD1217-2-V1 Thermal Camera Firmware - iptcs_h3_en_std_5.5.18_191202ipcamtalk.com
HIKVISION DS-2TD1217-2-V1 Thermal Camera - iptcs_h3_en_std_5.5.22_201106
HIKVISION DS-2TD1217-2-V1 Thermal Camera Firmware - iptcs_h3_en_std_5.5.22_201106ipcamtalk.com
Yes did that, no luck unfortunatelyDid you try factory resetting after updating firmware?
Cracking idea, will put it in a box out of the way as sparesIf you think the thermal camera module might still be okay, there's a chance it is compatible with your other cameras, so you should keep it around in case the thermal calibration shutter stops working like it did with one of my cams.
Hey,
Has anyone got a working firmware for the DS-1217-3/V1?, I tried to upgrade one recently and now the thermal seems to be trashed, optical still working fine though.
I am not sure if I did something wrong here, but everything was fine before the upgrade.
Currently I'm on iptcs_h3_en_std_5.5.22_210702
But the thermal is toast
here is the output of the thermal now.
Loyd, question. Did you have an SD card plugged in when you did the upgrade? What about afterwards?Hey,
Hey,
