New Firmware for IPC-HX5X3X-Rhea_MultiLang_PN_Stream3_V2.800.0000013.0.R.191202.zip
Thanks for the update, @EMPIRETECANDY! Snagged it :)
Is it safe to assume all the bugs noted previously, such as cameras crashing and the sub-stream configurations resetting to defaults, have been addressed?
Or go to live view and select the icon on the bottom left to pull up the zoom/focus. You get a bigger picture to look at then than the zoom/focus tab. I never use the zoom/focus tab.
Reactions: Dramus and 105437
I found a bug, I'm not able to get a preview on the Zoom/Focus tab.
sigh Dahua must do almost no QC on their firmware at all
I'll just stick with v15 on everything.
Hey guys,
Here is the latest new firmware for these models, there has a little update for some bugs, details please check the Release Note.
This new firmware is a important update for Fixing Security Vulnerabilities
General one is without dahua logo
DH one is with dahua logo.
Models support.
IPC-HDW5231R-Z/ZE
IPC-HFW5231E-Z/Z5/Z12/ZE/Z5E/Z12E
IPC-HDBW5231R-Z/ZE
IPC-HDBW5231E-Z/ZE
IPC-HDW4231EM-AS/ASE, IPC-HDBW4231F-AS, IPC-HDBW4231E-AS/ASE , IPC-HFW4231S,IPC-HFW4231E-S/SE.
IPC-HDBW4431F-AS
IPC-HDW4XXX-ASE
IPC-HDW5XX-ZE
IPC-HFW5XXX-ZE
IPC-HFW4239T-ASE
IPC-HDBW4239R-ASE
IPC-HDW5831R-ZE
IPC-HDW5631R-ZE
Please make a default after make the update, and make sure the cams you are using is on the list. Hacked Chinese models, please don't use this firmware to update. If you have any doubt just send message to me for double check.
Andy
Hi Andy,
I tried to download IPC-HX5X3X-Rhea_MultiLang_NP_Stream3_V2.800.0000013.0.R.191202 from Index of /images/Files/Firmware, and there are newer versions. None of them works.
Can you please share the link for the V2.80?
Thanks
It doesn't work for the LNB8005-C. But your first one V2.64 works well. And after successful upgrade, the camera is labelled as LNB8111. That suggests the two models are very similar.
How long does it typically take to do the upgrade to new firmware? I've tried uploading the newest firmware from Andy's link and it just says transferring files and seems to be hung up. Been like this for 15 - 20 minutes
Well, the operation timed out. So, either I'm doing something wrong, or we have a communication issue.
Current firmware on the camera(s) is:
Software Version 2.460.0000.3.R, Build Date: 2017-01-05
WEB Version 3.2.1.413002
ONVIF Version 2.42
Do I need an intermediate firmware version?
Camera(s) are: DH-IPC-HDW5231R-Z
