fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,419
Again you proved that you don't understand the wpa2 issue...all my wifi access points have been patched for krack.. that's at the vulnerability itself required the attacker to be local to the access point or router... Well the Hikvision backdoor a lot anyone with internet access to attack your system...Actually I do understand the issue with WPA2 - should have been replaced years ago since all the encryption keys have been used more than once, but my point is that your likely happily using your wifi now aren’t you, or are you roaming the streets with a placard telling people to repent and turn off their wifi? keep up the crusade, seems the only reason you’re in the Hikvision sub-forum.
And yes I must be a fraudster since I commit the sin of installing RG59... oh look TVI can do 4K over coax. Its cool I can tell your just trolling me![]()
