Pfft...turrets...I prefer that people on my property know they are being filmed. And this tracking them as they walk by on the sidewalk does a good job of that:I prefer turrets myself. I like the look of them better. I do run one bullet as an LPR camera because I need the longer focal length its provides to capture plates at ~100'.
The king of cameras right now is the 5442. It is 4MP with a 1/1.8" sensor. If you want to go 8MP make sure the sensor size is 1/1.2"...But, it will be pricey.You guys are a wealth of knowledge, thank you so much!
So I’m thinking:
Outside
VarFocus - 8MP Starlight Lite Varifocal
3.6 - still using 8MP StarLight Light - Couldn’t find fixed 3.6 from Empire Tech
2.8 aka doorbell - Still thinking the Reolink POE as I don’t want to have to depend on wifi
Inside:
Indoor wired 4MP POE - wife approval factor high as they’re tiny - wired and on the bottom of my vaulted ceilings
Thoughts or suggestions on changing something?
Thank you guys!
Unfortunately it can get confusing. Empiretech and Loryta are the same thing, but offer different units. If you search for Loryta you will probably find what you are looking for.You guys are a wealth of knowledge, thank you so much!
Thank you guys!
Wow that is a significant change!Do not chase MP - you are looking at 8MP on the same size sensor as a 2MP so the 2MP will kick its butt ALL NIGHT LONG. You would need over 4 times the light to get the same brightness as a 2MP camera.
Most here will tell you that 4MP is the sweet spot for surveillance cameras.
But if you go 8MP, it needs to be on the larger 1/1.2" sensor.
You would be much better off with the 4MP 5442 series that is on a larger 1/1.8" sensor than the one you are looking at that is 8MP on the 1/2.7" sensor.
It will make all the difference in the world.
Almost any camera can do well in the daytime with enough light, even cameras that are 8MP put on a sensor designed for 2MP. But keep in mind that usually the processor and other stuff are still designed around 2MP, so the camera struggles trying to keep up with 8MP worth of data.
So buying an 8MP camera on the same sensor as the 2MP processor means that the processor is potentially working 4 times as hard for the 8MP camera. The camera you are looking at was designed for 2MP, so when they pop an 8MP lens on it, the processor is still the same and has to work harder. In some situations that is problematic.
Here is another real world example with a deer. Even with a floodlight, there simply wasn't enough light to make the 4MP on the sensor designed for 2MP to go into color. Imagine how much darker trying to squeeze 8MP on it will be.
And a 4MP on the proper 1/1.8" sensor camera (different deer LOL) that the camera was able to go to color based on the larger sensor:
Which do you think is the better image? The same thing applies whether it is a 4MP versus 8MP on the sensor sized for 2MP.
I’m going to go read this and report back, should’ve already done that sorry guys!The cameras I referenced in this thread have links to the EmpireTech/Loryta/Dahua OEM cameras on Amazon we talk about:
The Importance of Focal Length over MP in camera selection
At the urging of several folks here, I created a thread to show the importance of focal length and how focal length can be more important than megapixels (MP). I mentioned some of this in the post regarding The Hookup’s latest video demonstrating different cameras, including one sold from a...ipcamtalk.com
No worries. Just don't buy anything until you are sure what you need.I’m going to go read this and report back, should’ve already done that sorry guys!
