You dont want to run a switch in a hot attic. You have siding, you dont have to run the cables exposed. Run it in the wall or behind the siding/trim.Also I'm trying to figure out where to stick my switch. I was thinking of the attic but then I would have to run Ethernet down to the basement and over to where the nvr is. Then I though why not stick the switch in the basement. I would like to stick the switch in the basement but then I would have to run the Ethernet from the cameras to the basement and it would be easy for anyone to cut the Ethernet cord to the cameras becaube it would be right in front of you. So pros of attic is the Ethernet would be up high. Pros of basement is I don't have to run Ethernet down 2 floors and I already have power outlets in the basement which I don't in the attic.
I bought a used to switch with built in fan so it should be about to handle attic heat maybe not though. I'll look into running wires behind siding.
you likely dont have ptz enabled one of the cameras...Alright so i have the cams setup and blue iris is displaying the cams. both cams are the same. When i click on one cam i can control the zoom and it displays the proper date and time in the upper right corner. When i click on the other cam the zoom, focus, ptz controls are all greyed out and the time and date in the upper right corner is from the year 2000. How do i correct these issues on this camera? I tried searching but found no answer. Also im not sure how to tell blue iris which hdd to record to. Where do i choose the recording hdd? Thanks
