Allright , so i should not use the DHCP setting on the camera , i should just use the static ip adress and just change the last letters to a range outside the routers DHCP, and this will not cause problems Even though i run router to switch to PoE switch for the cams ? I dont need to change anything other then in the cam interface menu put static ip and change the last letters - no need to add or change anything Else then that - press save and good to go ?
