Need firmware to chinese IPCAM-100 ip camera.
System Setting -> Usermanage -> Dev Authentication -> Digest
This option sets the rtsp authentication.
Its really works, thank you for the tip!
No problem, man. Also remember that you have additional accounts in your camera - user/user and operator/operator - make sure to change their passwords too before you put your camera in to the internet :cool:
So I can log into this camera through IE11 but Milestone software can see the camera but can't talk to it so I tried ONVIF Device Manager and it cannot even access it other than getting that its a Dahua Product. If I didn't know better I would say ONVIF is not working on this camera has anyone else had an issue like this?
OK got this to work for the most part on ONVIF Device manager had to change the port from 80 to something else seems like it was being blocked. Milestone still can see it but not pull any data from it to set it up. this is the error message:
TITLE: Milestone XProtect Management Client 2019 R2
It was not possible to connect to or receive information from the hardware '192.168.3.13'.
Verify that the following is correct: address, port, user name, password and hardware driver.
Alternatively use auto-detection to find the hardware.
BUTTONS:
OK
BUTTONS:
OK
manually add device > add/ create user / pass credentials > select universal 1 camera driver, when prompted for address and port make sure universal 1 driver is selected, > confirm setting of camera in milestone is the same that your camera is setup as , (image attached)
Hi All.
A very newbie here. I have a IPCAM-100,
It was supposed to contain a CD with IPCTool.exe but it was missing.
I found on the web IP manager and so was able to discover it's IP address.
I can login to it and see all the settings, however I cannot get a picture.
When using the LiveLive button I get "OCX plugin needed.
I have tried viewing with Chrome and IE both with the same error, in IE I have manually enabled all the Active X settings.
In Chrome I have failed to install a OCX extension.
In Chrome I loaded MyIPCam extension, added the required settings and get .....
"Response is received but no image: Error 404, try manual settings."
I have installed Yawcam, selected http etc it says it cannot connect.
Any help would be great.
Thanks
Dear All! I bougt this kind of PTZ camera because it is really good pictura for a reasonable price. I would like to use this cameras, with Synology survillance station, but it cannot activate it. In the ONVIf mode, the software is recognise, but it has no picture. This camera has a 2020 fw model. Have you any experience about this kind of survillance cameras?
Thank you for the help.
Hi All.
Thanks
Hi All.
Thanks
Use internet explorer.No other browsers support the plug-in.
Hi All, I just bouth 4 of this IPCAM-100.
2 of them have this firmware and they work fine:
KernelVersion:​
Thu Jul 9 15:46:54 CST 2015​
ServerVersion:​
WS5.5.1527-20190824-DANALE-HTAF​
WebVersion:​
V2.3.4-20190822​
2 of them have this firmware and they didn't let me to see with the app the recorded video. I can only extract the microsd and see the video from a PC.
KernelVersion:​
ServerVersion:​
WS5.5.1731-20190420-DANALE-HTAF​
WebVersion:​
V2.3.4-20181220​
Anyone have an Idea where I can find the first firmware? Or maybe how to download it from my webcam?
Thanks
