zero-degrees
- Aug 15, 2015
- 1,335
- 849
@Dr. J. I understand you are "New" to all this but I am not sure how much more the forum can break things down for you.
Without your camera connected physically to Internet Access you own and can configure you will NOT view your camera remotely. Live, Recorded, ect. Without being connected to a network you can configure this will not work.
The Xfinity "Hot Spots" you speak of that allow Comcast customers to access will not work. This is a public network that requires sign in and authentication and is not meant to be used continuously by any device, and a Camera can not log back in. Also since this is a "Guest" network you are not allowed to configure it. You will be unable to access port forwarding or settings.
The reason you will need to stop by weekly and swap cards is because you will have no way to view the footage stored on those cards unless you physically remove the card and connect it to your computer. If you wait to long and footage starts recording over itself then you defeat the purpose because you will lose recording.
As for a cellular camera setup the one @looney2ns referenced is NOT what I would recommend or utilize, nor is that what I was referring to as these will not be high quality HD images that a traditional security camera will give you. What i was speaking of are the links following.
Amazon.com : Wireless Jobsite Security Cameras : Camera & Photo
http://www.brickhousesecurity.com/c...security+cameras/cellular+security+cameras.do
http://radiusvision.com/complete-systems/mobotix/
