randytsuch
Pulling my weight
- Oct 1, 2016
- 496
- 179
Every once in a while we lose power, so I bought a dual fuel portable generator.
Was a low budget project, so got a relatively small one, 4600 watts on propane. Note that you get about 10% less watts on propane.
I plan to only use propane so I won't have to worry about gas getting old, and having to clean out old gas out of the generator.
I have two 30 lb tanks for it. And I could use gas if I get desperate.
I also "built" a power invertor to go with my generator. I have a DC power supply, and an DC to AC pure sine wave invertor that provides clean power to my electronics.
Description here
Not sure if I could power electronics safely from my generator, but figured it was better to be safe so I put that together and have it stored in a tote bin for when power goes down.
I also adjusted my generator's speed (throttle screw), so its at 60 hz under load. It's pretty easy to do if you have a kill a watt or similar to read the frequency.
Lost power once, for about a day since getting the generator. Since internet still worked once I powered my modem and router, it was really nice to have backup power when most of my neighbors were screwed.
I only am going to use the gen to power the fridge and freezer in the garage, and some electronics. And some lights if its at night. I live in so cal, so no real temperature extremes to deal with
Randy
Description here
Randy
