They are talking WEEKS for some areas to see power restored.That'll take some time to repair
Well just had both my local Kohler and Generac dealer/electricians come out for a quote. Still waiting on both quotes. Kohler wants to do 26kw (I could probably size down to the 20kw) and the Generac dude wants to do a 24kw. These are the air cooled NG models. We will see how many zeros they want to add to the quote but I'm guessing somewhere in the neighborhood of $13k - $15k.
I thought about buying the biggest portable inverter type generator and having a manual transfer switch and inlet wired to the outside panel but you can only get about 30A out of those inverter generators which isn't ideal. I'd have to wire up a soft start to my A/C and I'm not really keen on doing that since the unit is brand new and I don't want to fub up the warranty by bolting aftermarket parts onto the outside condenser.
The A/C is on a 30A breaker. The RLA on the outside unit shows 20A. In-rush current is much higher without a soft start wired in. I'd have to ask my HVAC company that did my A/C install if they could wire it in.Do you really need more than 30a?
Personally, I have both! Good to have some redundancy.
This shows the portable generator plugged into the 30a inlet, with the interlock kit. Pretty handy
I bought a 20,000kw from generac in 2011, The first thing I had to do was upgrade my Natural gas meter, something to check into. On natural gas it does 18,000KW . I wanted it especially for A/C Unit, Mine is 2 tons so it does start it but I did end up puttingWell just had both my local Kohler and Generac dealer/electricians come out for a quote. Still waiting on both quotes. Kohler wants to do 26kw (I could probably size down to the 20kw) and the Generac dude wants to do a 24kw. These are the air cooled NG models. We will see how many zeros they want to add to the quote but I'm guessing somewhere in the neighborhood of $13k - $15k.
I thought about buying the biggest portable inverter type generator and having a manual transfer switch and 50A inlet wired to the outside panel but you can only get about 30A out of those inverter generators on NG which isn't ideal. I'd have to wire up a soft start to my A/C and I'm not really keen on doing that since the unit is brand new and I don't want to fub up the warranty by bolting aftermarket parts onto the outside condenser.
