Would this camera capture out to 120' or so? I have a 437 and would like to get this to grab plates from the other direction.
Thanks much. Would that other camera you reviewed, can't think of the name, reach out to 120 feet? Think it the 3rd version of the camera. I know it doesn't do ANPR capture, but if it would capture the 3m plates better, it would be a win.At night, not a chance.
During the day you may be able to make out most of them with some digital zoom at 120 feet.
That makes more sense, it has the processing ability and storage built into the unit, and does not require an special NVR or system running on the network just for LPR data logging. Not sure if I skimmed over that part or if it's not a prominent detail in your review. That is really cool it doesn't require a special NVR or a machine with LPR software on the network.This camera actually reads the plates and logs them, so the processor is bigger to perform that and it has internal storage to store the plates.
It also has more capabilities like being able to open gates and what not.
It also has a speaker.
It has 4 larger lights that can do infrared or white light.
All of that means it needs to be larger to contain all the extra stuff.
				If you get one let us know what you thinkI have found out that there is a LPR ITC431 with 10-50mm lens. Of course the cost is quite a bit more, but I may snag one down the line just to see.
I was just looking at it, because I don't recall being able to select the (parameters) to use in the file name. I don't think you can. You select the main folder where you want the snaps, and within that main folder will be a subfolder by date (2024-07-11). Within that dated subfolder will be an hourly folder (00 is 12am). Within that folder will be a folder with the minute of the snap. (21 ) etc. a snap in those folders above would have beenntaken at 12:21 am on 7/11/24 if that makes sense.Thanks. Testing IPC-B74IR-Z4-AI right now, ANPR captures are good and License plate # is embedded in OSD but can not put it in the file name. Was trying to make a central database that collects data from 2 cameras
