- Dec 12, 2014
- 45
- 1
When did you contact support about this issue? I ask because it looks like your firmware is only a few months newer than mine. Also, have you contacted BI support?Seems like my firmware is more updated than yours, I got it after tech support WebEx to resolve the issue but overall it seems it's an issue with bi and not the camera.
Thank you Sir, i hope we get an answer for this !I downloaded the file. Thanks! I messaged BI Support a few hours ago. I will update here.
in bi, go to alerts, then select sound alarm using pc or camera speakers...select send to camera if supported...then test..see if you get audio from the camera.Still unable to get this working. i found this thread, changed config to match... still not working in BI, works in native app...
https://www.ipcamtalk.com/showthread.php/3017-Hikvision-2-way-audio-help
To clarify, did you do the test as explained? I am not asking you to use the mobile app..this test is to see if the blue iris server can send audio to the camera.Thanks for the reply Sir,
tested - no sound is coming out of the camera. native app works...
Is the camera wireless? test it wired..i have seen weak wifi connection cause audio problems. I know 100 percent for certain that the camera works with blue iris for talk audio...Fair questionBut yes, Sir. i understood the logic in your suggestion. tested from the BI server, seems as BI server is unable to properly send commands audio to the camera, i mentioned in the native app it works, to eliminate the possibility of the camera being at fault.
I dont have the same camera anymore. I did have it. I used the talk function. I also have the LTS/hikvision 2432 and it works fine. The firmware and hardware are the same. The settings appear to be correct...you can try contacting support and see what he says...you will need to give him direct access to the camera.Camera was on Wifi at initial state and now it is now on POE, no change.... @fenderman, if you have the same camera would you mind please adding screenshots of your config, page by page for the software setting as well as the camera config?
i know its asking alot, but only if you have time. i know for sure it SHOULD work with this camera, and i am sure the camera function with no issues as it works with the native app. so there must be SOMEWHERE where there is a missing config.
where it is , its the question lol.
