iamnothim
Pulling my weight
I just discovered something that makes perfect sense. (unfortunately) If the SFP is upside down on the $36 switch then the TX port will be on the left whereas on a normal switch with a normal SFP the TX port will be on the right. "You Got Ta Roll Me, You Got Ta Roll me"
AND. DOES THE INTENSITY OF THE LIGHT FROM THE MODULES LOOK STRONG ENOUGH TO WORK. THESE LOOK THE SAME AS THE ONES I SENT BACK.
