Sounds good. I gotta hunt it down on the forums lolIf you bought from Andy, then get from him as it tends to be better than what Dahua provides...
I just noticed I dont have the Smart IR featureBut a good rule around here is don't fix what ain't broke...If you are able to get clean captures of plates day and night, no sense bothering with a firmware update and risk messing that up!
With the exception of few cams were I was testing firmware for Andy, I have not updated any of my cameras because they are working for me.
You don't want to use smart ir for plate captures. you want the IR at 100% max all the time.I just noticed I dont have the Smart IR feature
awesome good to know. I think once I get everything dialed in, im gonna make a Explain Like I'm 5 LPR technical side of things guide. like installing openalpr and configuring it. All the information is out there, but not centralized yet.You don't want to use smart ir for plate captures. you want the IR at 100% max all the time.
Firmware check thisIPC-T5442T-ZE IPC-T5442TM-AS IPC-T5842T-ZE SMD 3.0 Smart IR Latest New Firmware From EmpireTech
Hey guys The Smart IR firmware with SMD 3.0 V2.8 2022 Aug Version has been released. The update is mainly for Smart IR, New Security Baseline function, highly recommend to update, esp the 4K models. This firmware is working great with the help of @Wildcat_1 , has big improvement on the 4K...ipcamtalk.com
For the green/blue box do you think it's not good enough angle to grab captures? I guess I can test it out before everyone heads home from work.Max zoom is problematic with some people, but if you can get clean captures, that is what is important. The Red one gives a slightly better angle, but I think either will work.
