Low-light struggles / improving image quality.
Nice. I like the apparent dark capabilities.
I have 2 5442 and they are good, but it could be better. Is the IPC-B54IR-Z4E-S3 a newer/better camera for night captures?
if you have 5442 in S3 variant (white/blue web GUI interface) - it's the same...
if older one (grey web GUI interface) - then newer...
Z4E means that this model have strong telephoto lenses - with zoom range 2x to 6x comparing to iPhone...
Here are some night captures showing various specimens walking past on the path.
This was the 20th/21st (took a while to process the video), so I am unsure exactly what settings it was running - probably very similar to what I showed a few posts back. I still have to try and tweak the focus at night. I am not sure exactly what DoF to expect, but I am assuming if I focus to the gatepost, this will provide decent focus on people just inside / outside the gateway?
Do we think this could be considered identify standard yet?
I have noticed a little bit of ghosting on some of these images interestingly, not sure if that was there before...
Here are some folk at 1AM inspecting an item.
Settings:
Still a bit of face blur, not sure if this is motion-induced or likely just resolution (lack of, relatively speaking) blur. Anyway, I have since sped up the night shutter to 6ms, as there still seems to be enough light.
Looking very good.
What is the distance to the target?
Sorry if I missed but is there any added IR or just onboard ? and is their any street lights close by? Any ambient light help?
Settings:
good picture...
if you want more details, the only solutions are optically zoom-in more and put there more light (white or IR)...
The distance is about 60ft to those targets, plus a bit to account for the height of the camera (2nd floor soffit). So not too bad considering camera position.
Mainly the onboard IR. The only additional light at in that example would be:
  • IR from a small overview turret, but this is over 80ft away from those targets and at a pretty poor angle.
  • There are streetlights vaguely nearby, but I am fairly certain they would be off at 1AM.
I may increase the optical zoom as an experiment, I think it has a tiny bit more in it, currently at 1177 zoom points. Likely a minimal difference though.
Also playing with the IVS setup, I currently have a tripwire across that pavement, but I have noticed it is missing some targets, especially at night. Still tweaking.
Overall very happy with the result.
We have very similar scenes as far as distance and light
I'm about 2/3 zoomed.
Center of street is 50, edge of porch across street is 65ish
I run 4-6ms and 10240 bitrate
Home_Street-5442-Z4-S3_main_20241020200732_@1.jpgHome_Street-5442-Z4-S3_main_20241020200316_@1.jpgHome_Street-5442-Z4-S3_main_20241228183325_@1.jpg5-192.168.1.110_Street-5442-Z4-S3_main_19691231190000_@1.jpg
First impressions
1/3 sensor on 4MP is really so bad I would toss it and start over
Other
  • Turn off Variable bitrate and use CBR (constant)
  • turn off h.265 and use h.264 (or better h.264.h if it has it)
  • increase bitrate from 4096 to at least 8192, better 10288
  • exposure will need to be at least 1/50 preferably 1/100 or faster
  • hopefully there's a Gain setting you can increase
I’m curious as to why h.264 over h.265?
Do you have an SD card in the camera? If not, I would recommend it. It's a good way to review footage with the IVS rules overlaid on top.
Very nice. You have a better angle of the street itself (of course the main purpose of my cam is people entering my driveway, but it's nice to capture them walking past too), and are possibly getting slightly better face captures. What is the best way to know if you are 'running out' of bitrate? Mine is currently 8192 CBR, with 15FPS.
Currently, no. I have the 'Auto Upload' function pushing events to a server. I may do this though, to be able to review the footage with the IVS rules overlaid, as you mention.
No downside going to 10240 I didnt see any real improvement past that
With some systems, like Lorex, they only give the option of H265 and 4096kb with their 8mp cameras. When there is a big change in the image (motion, exposure) it really pixelates and looks terrible. With H264H, there is no pixelization. I believe it's related to how the image is refreshed. I believe the reason they do this is the cheap low horsepower processor and outdated design. Found this out the hard way.
Yes, I understand. I think currently my cam is set to plain H.264 - I am not sure what benefit H.264H brings?
