- Jan 30, 2017
- 835
- 320
I will probably go with his recommendation. My 13 year old daughter plays on the computer more than I. She's a Sims freak. I play Battlefield FPS games. Just haven't had time between working on my brother in law's house and working on reloads for this past hunting season. I guess I'm saying I need to find an alternative to my gaming system.
Just gonna build a box I think. Will the I5 processor you recommended run 10-12 HD ip cams? Sounds like a basic box. No video card so use on board video. Ram recommendation? I figure I'll just share my gaming monitor. It has plenty of input/outputs. Doesn't need a huge power supply.
While trying to find a pc I found the system requirements for blue iris. It says for multiple hd cams use a nvidia video adapter. Confused on if I should use onboard video or it does get acceleration from a graphics card.BlueIris wont give you hardware acceleration with that NVIDIA 1080 card; more than likely you'll have to remove it for BlueIris, presuming this is a modern Intel system.. if its a standard cheap AMD gaming rig you wont get any hardware acceleration at all and decoding multiple HD video streams 24/7/365 gonna load that system to the brink and you'l be left choosing between cameras and games.
For a temporary purpose to evaluate BlueIris it might be suitable; just keep in mind that BlueIris's performance varies dramatically depending on your underlying hardware.. 10 cameras can crush a machine w/out hardware acceleration, while with the correct video subsystem the same 10 cameras will barely put any load on it at all.
